dick seiders
Would appreciate if someone out there would provide info on the topic that is brief, concise, and complete. Call it a hose change info kit if you will. If one is created it will save all of us at the 5 yr change , and those down the road a ton of research. for ex:
Oil hoses are vans supplied and good for 10 yrs.
Fuel line hoses are Rotax? Are they supplied by Vans, Rotax, and how do they compare to alternative teflon stainless hose fplks and what is the approx. diff in cost?
Engine water coolant hoses I presume are Rotax supplied?
Radiator coolant hoses come from where? There are no VA nos so not Van's?
Hose removal tool from Amazon should be part of this as well.
Any other necessary info as well.
I would certainly appreciate a primer on this and I suspect the many who are coming up on it would as well. Many thanks.
dick seiders 120093
dick seiders 120093
