dick seiders
cranked today and during latter part of warmup (it was cold 28 degrees) B>Betty said LOW FUEL PSI. The dynon psi indicated FULL max psi. Did'nt know what was happening for sure altho I suspected the fuel pressure sensor so I shut down, and plan to try a new sensor tomorrow. While looking at the engine after removing top cowl discovered a small leak of coolant coming from hose on no. 3 cyl which of course is the most difficult to get at. Good news is it was found
Any comments on either topic is well appreciated.
dick seiders 120093
dick seiders 120093
