Old 02-12-2017, 07:21 PM
johnbright's Avatar
johnbright johnbright is offline
Default WTB nav light fairings for W-415 "flat top" wing tips
I need to mount Aeroleds Pulsar EXPs (that puts nav/strobe/taillight on the wingtip) on original short wing W-415 "flat top" wing tips. Wondering if I can buy some fairings to glue on or if I'm gonna be shaping clay.
Or if anyone has the Flyleds aluminum ribs to spare... Flyleds has the lenses but no longer carries the ribs... that would put nav/strobe in the wingtip LE, a taillight would be mounted to rudder bottom.
Maybe I buy the Flyleds lenses and make the ribs... any pireps on Flyleds?
John Bright, RV-6A, at Finish Kit
Continental Titan IOX-360, 8.5:1, vertical sump, SDSEFI EM-5, injectors in heads.
Aeroelectric Dual Alternator Single Battery/SDSEFI dwg ECUdual4, dual batteries TBD.
Old 02-13-2017, 07:55 AM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default possible tip lense available
I have two lenses for 1996 RV4 project I bought that had leading edge lights in the wings. Wont need the tip lense. Call and we will see if they work on your wing tips...Larry 765-505-1160
Larry DeCamp
RV-3B N243RV flying
RV-4 fastback project in the shop
Clinton, IN
Old 02-13-2017, 08:50 AM
RV8_Cat1's Avatar
RV8_Cat1 RV8_Cat1 is offline
John, I have a set of the W415 wingtips with the fairings already glassed in. I am planning on putting the recessed lights. Going to cut out the fairings!
Chris Triche
