Old 09-27-2011, 09:52 AM
bruceh's Avatar
bruceh bruceh is offline
Default Location for parking brake handle?
I have a parking brake installed on my firewall just above the pilot's rudder/brake controls. I'm trying to lay out the general location of things on the instrument panel, and I'd love to hear your opinions on where the parking brake handle should reside. I have a T handle from ACS with a locking button in the center.
Ideally, I would like to have this on the pilot side, and NOT on the panel, but somewhere underneath or on the side of the fuselage. Less to deal with this way if the panel has to come in and out. Looking for ideas on how to mount this.
Bruce Hill
RV-9A N5771H flown over 500 hours!
2017 VAF donator
EAA Tech Counselor
Old 09-27-2011, 01:07 PM
lorne green lorne green is offline
I plan on installing my red parking brake T handle for my 7a on the pilot's side just above the eyeball vent.
This location for easier access when standing on the wing, dumping the brake valve without climbing in.
Lorne
RV 7a tip-up
Pre-cover MD-RA Inspected.
Canopy completed. Bonded with Sika-Flex.
Up on her mains, Beringer front wheel. Firewall Fwd and wiring on going.
Old 09-27-2011, 02:09 PM
Dan Langhout's Avatar
Dan Langhout Dan Langhout is offline
Default My Solution
I used a regular round knob "detent" cable for this and inset it's mounting so the knob doesn't protrude as much. I figure that the parking brake is rarely used - but if I happen to need it, I don't want to have to hunt the handle up under the panel somewhere.
Dan Langhout
2018 =VAF= Dues PAID . . . . .
RV-7 N528DP slow build
First Flight July 26th, 2014
324 hours and counting . . . .
Now based at Moontown (3M5)
Old 09-27-2011, 02:42 PM
glenn654 glenn654 is offline
Dan,
Where did you get that nice looking panel?
Please post some more pics if you have some.
Glenn Wilkinson
_____________________________________________
RV-4 Sold
N654RV @ MLJ
RV-7 Coming Soon
N987RV Reserved
2015 Donation Gladly Paid
"Maintain Thy Airspeed, Lest the Earth Arise and Smite Thee"
Old 09-27-2011, 02:45 PM
Birkelbach Birkelbach is offline
That is where I put mine and I'm glad I did. There have been many times when I just wanted to dump the brakes without having to get in. Now if there were a way to set the brakes without getting in...
Phil Birkelbach
RV-7 727WB - Flying
Pitts S1C - Restoration
Christavia Mk1 - Fuselage
www.myrv7.com
Old 09-27-2011, 03:09 PM
Bavafa Bavafa is offline
This is where I have installed mine and I use it more often then expected.
BTW, this looks like is going to turn like a very nice panel.
Cheers
Mehrdad
RV7A - IO360M1B - SOLD
Dues paid
Old 09-27-2011, 05:04 PM
Default Don't want to hijack the thread . . . .
Originally Posted by glenn654 View Post
Dan,
Glenn Wilkinson
I made it (glass and carbon fiber).
One pic - still a work in progress.
Dan Langhout
Old 09-28-2011, 12:03 AM
jjconstant's Avatar
jjconstant jjconstant is offline
I orignially put my parking brake handle on the small vertical bulkhead by my left knee (RV7A). I'm short and the problem was that when I pushed on the brakes it had the equal and opposite effect of pushing me back in my seat...to the point I couldn't reach the parking brake to engage it
I moved it to the power quadrant and have been really happy with it there. I use it at start up, run up and shut down on uneven ramps now.
Jeremy Constant
Old 09-28-2011, 01:21 AM
AltonD's Avatar
AltonD AltonD is offline
I left the tab where the manual elevator trim was supposed to go and installed it there.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~800 hours since Aug 2010
N4IDH
Construction Log
“The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.”
Mark Twain
Old 09-28-2011, 03:44 AM
N941WR's Avatar
N941WR N941WR is offline
I mounted mine in the upper left of the panel, right where I look when taxiing or taking off.
One secondary advantage of that location is that it made routing the cable a snap.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
