Old 02-10-2009, 11:25 AM
macrafic's Avatar
macrafic macrafic is offline
Default Riveting the Fuselage
I posted this in the general site, but I think it got lost in all the traffic. Since it is about an RV-7A, I thought I would post it appropriately here.
I'm at the point, just before "flipping the canoe", where the side skins get riveted on. After that, you are instructed to finish riveting on the bottom forward skin. I have a couple of questions (RV-7A).
First "...finish riveting the bottom skin". That implies that the riveting has been started. Mine hasn't and I can't see anything in the previous pages that indicate I should have started. What did I miss?
Second, nowhere can I find where you rivet the bottom skins where the mid fuselage overlaps the reard fuselage, and the 623 corner ribs. Again, what did I miss? Do I do it now, or is this waiting until later for some reason.
As always, grateful for the resources out there who have forged this path before me!!!!
Rich and Cindy Macrafic
Rochester, MN
One month to painting and test flying
Old 02-10-2009, 12:48 PM
Jkkinz's Avatar
Jkkinz Jkkinz is offline
I don't have my plans or book here but I will try to answer your question. The rear fuselage bottom and side skins get riveted to each other and to the bulkheads and side stringers. There are a number of rivets that do not get attached so you can get the longeron between the skin and bulkheads. The center fuselage bottom skin is riveted to the seat ribs, rear spar and main spar. You then mate the rear and center sections of the fuselage. You temporarly install the longerons at the same time. Next comes the side skins from the aft fuselage to the firewall. Lots of drilling countersinking and clecoing. Make and install the bracing for the forward fuselage, attach the firewall, cut and drill the forward fuselage floor stringers and continue matching and drilling everything. As you complete the canoe you will have used a "lot" of clecoes. You will probable take things apart several times for countersinking and deburring as well as any priming. This a rough description of the process from memory but it should give you some idea of what i mean.
Jim Kinsey
7A Finishing and Engine
AFS screens
IO360A1A, Catto 3 blade
N527K reserved
Donated thru 2018
Old 02-10-2009, 05:15 PM
macrafic's Avatar
Thanks Jim. I follow you, and am at the point where you ended. Now, i have to disassemble everything, debur, countersink, etch, prime. Once that is done, I have to start riveting together. That is where my questions came in.
I see the point in the instructions for riveting on the side skins. I'll also assume that the word "finish" in "finish riveting the forward bottom skin" should really say "just do it", since I haven't started anything to "finish" yet. But, I don't see the point where the rear and middle fuselage floors are riveted together (or where the 623 side ribs get riveted to the floor).
Do these two fuselage pieces get riveted BEFORE riveting the side skins on or after (or doesn't it make a difference)? Is there any particular time for the 623 ribs to get riveted to the floor?
Thanks.
Rochester, MN
Old 02-10-2009, 05:38 PM
Lionclaw's Avatar
Lionclaw Lionclaw is offline
I'm at the same stage on my 9A. I just finished the disassembly/countersink/dimple/clean/prime process for my fuse parts, and will start reassembling them tomorrow.
The instructions are pretty sparse. I'll complete the small list of pre-assembly tasks in the instructions and then reassemble and start riveting.
I've been scanning Dan and Mike's build logs for tips and pictures (my9a.com and rvproject.com).
Andy Compton
RV-10 - N432AC (building)
RV-9A - N643AC (built,flying,sold,missed)
My blood and sweat, the Wifey's tears
http://picasaweb.google.com/pilotandy/
Old 02-10-2009, 07:30 PM
Jkkinz's Avatar
Rich,
Try this website. Jason did a great job in detailing the construction process. It should answer your questions
http://www.rouault.us/?page=fuselage.asp
Jim Kinsey
AFS screens
N527K reserved
Donated thru 2018
Old 05-22-2017, 07:45 AM
rapid_ascent rapid_ascent is offline
This is an old thread but I guess things haven't changed. I read through the instructions a couple of times to make sure I hadn't missed it. No reference to joining the aft and mid fuselage sections in the instructions.
My plan is after the side skins are removed for dimpling to take apart the mid and aft sections, deburr, dimple, prime the overlap area and then rivet. I'll have better access before adding the side skins back on.
Oh did I mention how much I love drilling countersinks.
Ray Tonks
2018 Donation Paid
RV-7 Fuselage in progress
* Fwd Fuselage Complete
* Mid Fuselage Complete
* Aft Fuselage Complete
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
Shop Setup - In Progress (Gathering Tools, Never Complete)
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 05-22-2017, 03:32 PM
wirejock's Avatar
wirejock wirejock is offline
Default Blog
I can't remember exactly but I documented the process pretty well in my blog
As others mentioned, mark the holes that don't get rivets.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 05-22-2017, 04:16 PM
RV7A Flyer's Avatar
RV7A Flyer RV7A Flyer is offline
My construction manual has a whole section in the Fuselage portion entitled "JOINING THE REAR AND CENTER FUSELAGE ASSEMBLIES".
Is that not what you're talking about?
Old 05-22-2017, 07:58 PM
Yep. Never says to rivet.
Ray Tonks
2018 Donation Paid
RV-7 SB Wings
* Ailerons Complete
* Flaps Complete
RV-7 Preview Plans
Old 05-22-2017, 09:37 PM
Z-EDD's Avatar
Z-EDD Z-EDD is offline
Ray, this is just symptomatic of the general descent into vagueness that the instructions make. They also never tell you when to rivet the F-796 parts in place, but you can safely do that now as well.
If you rivet without the side skins on make sure you can still slide the lower flange of the conical bend into place. For what its worth I had my side skins on.
Ed Fleming
RV-7- Wings done for now, canoe riveted.
Harare, Zimbabwe
Paid 2017
