Go Back   VAF Forums > Main > RV Ongoing Maintenance Issues
Old 06-18-2017, 02:38 PM
donwmack donwmack is offline
Default Help with intermittent Ray Allen Elevator Trim Switch
I have electric elevator trim installed with Ray Allen Servo, LED indicator, and rocker switch. I have had several times where the trim stopped responding. The LED indicator never has a problem. I have redone wiring several times at the panel but I am wondering if the rocker switch could be bad. I have done the following tests:
At the tail - Run 9V battery to the servo - It works going up and down - Means the servo is good.
At the tail - running ohms to ground at tail - Wire 1 - full continuity - Wire 2 no continuity
At the tail with power - Up trim I get solid 12V - Down trim I get intermittent from 3-5 volts
At the tail with wire 1&2 crossed - In the cockpit I get full resistance between wire 1 & Wire 2 without pressing the trim switch
I will reach out to Ray Allen as well.
Don Mack
RV-6A
N708CM
Old 06-18-2017, 03:02 PM
Kahuna's Avatar
Kahuna Kahuna is offline
Whelen LED Light Man
Don do you have a relay in the circuit? This is a common failure component. Very common.
Old 06-18-2017, 03:14 PM
Forgot to include that. I do not have a relay installed.
Don Mack
RV-6A
N708CM
Old 06-18-2017, 03:19 PM
flysrv10 flysrv10 is offline
I have had two of them replaced in the past ten years. They just burn out with use. Call them and either buy a whole new switch for the stick or buy the micro switch from them and solder it in yourself.
Old 06-18-2017, 07:07 PM
Paul K Paul K is offline
I have a couple sets of rocker switches and the indicators if interested. Let me know.
Paul K
West Michigan
Unfortunately in science what you believe is irrelevant
2017 dues paid up, reminder to renew 01-01-18
https://picasaweb.google.com/1033987...eat=directlink
Old 06-19-2017, 05:57 AM
Paul I only need the rocker switch. I tried emailing you back here and it said your mailbox is full.
Don Mack
RV-6A
N708CM
Old 06-19-2017, 11:23 AM
Sorry about that, fixing it now.
Paul K
West Michigan
Old 06-20-2017, 10:59 AM
krw5927 krw5927 is offline
I too have an extra new Ray Allen rocker that sits unused.
Kurt W.
RV9A
FLYING!!!
Old 06-20-2017, 08:04 PM
Thanks Kurt,
I have a switch on the way.
I hope that fixes it for good or at least until this switch wears out.
Don Mack
RV-6A
N708CM
