Old 06-18-2017, 01:58 PM
Freightdawg's Avatar
Freightdawg Freightdawg is offline
Question Rear Floor Pan Riveting
Just finished blind riveting the floor of the rear floor pans (after much cussing and sweating to wrestle them into place). We were about to get into riveting the side and rear flanges with 4-4s (per the plans) when I noticed the front floor pans were riveted to the tunnel with blind rivets.
Is there any reason the rear pan rivets need to be bucked vs pulled?
Thanks.
Jeff
Jeff Rich
RV-10 empennage done for now. Wings done for now. Working on the (SB) fuse (Section 43: Cabin Cover)
Finishing Kit is here! Check for the motor cleared
N313KC reserved
In the garage for now, KJVY this summer
Old 06-18-2017, 02:10 PM
Thanks.
Jeff
The factory has the real answer, but my answer would be "no". There is little, if any, difference in that application.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 06-18-2017, 02:44 PM
ERushing's Avatar
ERushing ERushing is offline
If you ever have to get the floor pans out again, blind rivets would be quite a bit easier to remove in that location...
Eric Rushing
VS, Rudder, HS, Elevator, Tailcone - Complete
QB Wings - Complete.
QB Fuse - In Process. Tail & Fuse are one.
Molalla, OR
Old 06-19-2017, 10:18 AM
Just got off the phone with the Mother Ship. Pulled is fine. The explanation I got was they try to use solid rivets wherever possible because they're lighter and less expensive.
Of course, if that's the case, then why were blind rivets used to attach the flange of the front floor pan to the tunnel?
That call just saved me a ton of sweat and cuss words I'm sure can be better utilized elsewhere.
Jeff Rich
N313KC reserved
