Old 06-15-2017, 07:27 AM
ERushing's Avatar
ERushing ERushing is offline
Default Cabin Top: Carbon Fiber Overhead to paint transition
Good Morning,
The Aerosport overhead console is finally mounted on the cabin top and I'm starting to work on the cabin top cosmetics and overhead to cabin top transition.
For those who have kept the carbon fiber look, how have you made the transition from carbon fiber overhead to paint on the cabin top above and around the door opening? I'm struggling with how to make the transition along the shadow line of the overhead console look good and not have a ridge of paint or overhead clear coat.
Any advise would be appreciated.
In the photo below, the shadow line will be the bottom edge of the green fine line tape. I'll sand the clear coat between the green tape and the raw carbon fiber/ flox blend line. I'm planning to put a single piece of thin fiberglass tape over the transition and then micro to near the shadow line. Sand smooth, fill, paint. But that transition from the actual shadow line to the paint has me perplexed. I'm planning to use a single stage PPG product for paint so no clear coat on the paint.
Thanks for your help!
Eric Rushing
VS, Rudder, HS, Elevator, Tailcone - Complete
QB Wings - Complete.
QB Fuse - In Process. Tail & Fuse are one.
Molalla, OR
Old 06-15-2017, 11:45 AM
Sandrews Sandrews is offline
Interested in seeing some pictures as well. I've got a molded in overhead console and I'm wondering about the transition also.
Old 06-15-2017, 12:06 PM
I'll be finishing mine in a few days. My plan is to mask the console and blend up to the exposed flange with micro, with the micro faired to the same thickness as the flange. Then remove the console, finish and paint the interior of the top, and finally glue in the console.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 06-15-2017, 02:25 PM
clutch22 clutch22 is offline
Similar to what I did, but mine was bonded in first with flox. Then I Micro'd to blend. It was pretty easy to keep the console masked off while I painted the rest of the cabin top. YMMV.
I found a few pictures from the build:
Andrew Austin
-Flying!
Dues Paid 11/27/2017
Old 06-15-2017, 05:01 PM
ERushing's Avatar
Nice work, Andrew. What clear coat did you use?
Eric Rushing
Molalla, OR
Old 06-18-2017, 12:29 PM
A satin clear from SEM. It has held up fine, but my center console's clear hasn't, but that's because of the seat harness sliding and beating against it.
Andrew Austin
-Flying!
