Old 06-12-2017, 04:53 PM
ClarkieSr ClarkieSr is offline
Default Painting baffles
I'd like to see to paint my engine baffling. Does a anyone have an suggestions as to what kind of paint to use.
Tom Clark
N646LC
Old 06-12-2017, 06:50 PM
DrillBit's Avatar
DrillBit DrillBit is offline
I used a hi-temp, so-called engine enamel from the local O'Reilly Auto Parts. Color was white, same as the inside of the cowling, which is recommended by many to make drips easier to spot.
However, once I was done with the red RTV sealing up all the airleaks, the pristine white baffles were much besmirched.
Unless you're really into looks, leaving the baffles unpainted probably makes no difference in cooling performance and lifetime.
Kurt Haller
P-town, CA (10 min from KLVK!)
N748PK, RV-9A
In final assembly...
VAF dues paid 5 Dec 2017
Old 06-12-2017, 07:32 PM
Carl Froehlich's Avatar
PPG single stage urethane paint over PPG epoxy primer. The same paint I use for the interior and panel (just different colors). Very durable. The baffles on the first plane look like the day they got painted 15 years ago.
Old 06-14-2017, 08:03 AM
-goose -goose is offline
Mine are alodined and hit with a coat of 2-pack epoxy primer.
John Keen
RV-7 almost nearly finished
Scone, Australia
Old 06-14-2017, 12:22 PM
ronschreck's Avatar
ronschreck ronschreck is offline
Same 2-part Imron that I painted the plane's exterior. Still looks good after 2100 hours.
Ron Schreck
IAC Director and National Judge
RV-8, "Miss Izzy", 2100+ RV Hours
Track Me
VAF 2018 Donor
"He who demands everything that his aircraft can give him is a pilot; he that demands one iota more is a fool."
Old 06-18-2017, 08:43 PM
Jwputnam Jwputnam is offline
Default Flame Proof?
Do you have a concern in regard to fire resistance of the painted baffles? I was thinking of just going my my interior primer, Akzo 463-12-8. Not sure if it would be totally fire retardant. Wrote to Akzo. No response yet.
RV-9A
Newbie
Dues Paid (and very thankful)
Old 06-19-2017, 06:29 AM
Baffle paint fire resistance would be #1053 on my list of 3 issues I'd worry about. If the fire is that bad, the cowl will be consumed long before the baffle paint.
Use a good primer and a good single stage top coat. The easiest way is to use the same paint and process as you will with the interior. Painted baffles is a simple thing to do and looks a lot better years down the road as compared to corroded bare aluminum.
Old 06-19-2017, 07:14 AM
RV7AJeremy's Avatar
RV7AJeremy RV7AJeremy is offline
Took mine to a powder coater. Right around $100 and they still look great.
Jeremy
ATP, CFI, CFII
RV-7 N424JD KCHD
EAA Tech Counselor
2017 Bronze Lindy
