Old 06-11-2017, 10:29 AM
texdog texdog is offline
Question High cylinder head temp at altitude
Yesterday at 14,500 ft. 0-360, 17 inches of manifold and 2550 RPM, my number one cylinder required 1/2 gph more fuel flow to keep it at 380 degrees or less and EGT was 150 degrees hotter. I was at altitude for over two hours. In addition my volts were running 13.8 to 14.1. The voltage alarm is set for 13.8, for low. Are these normal occurrences, do I need to check exhaust and intake gaskets and maybe alternator belt. The belt is 7 years old 750:00 hours, but looked good in March at the condition inspection.
T82 Fredericksburg,Tx.
Don't make easy hard!
Aircraft
RV6A owner
L19 sold
Dues paid 2015,16,17
Old 06-11-2017, 11:07 AM
brad walton brad walton is offline
Ive noticed higher CHT at altitude even as fuel flow for same speed decreases. I assumed this is a result of less airflow over cylinder heads due to less air density.
Old 06-11-2017, 12:10 PM
bret's Avatar
bret bret is offline
Air intake tube leak on #1? running lean from a leak?
2018 gladly supported
Old 06-11-2017, 12:25 PM
Super Moderator
Depending on the time of year and temps, it is normal to see a little higher CHT's at altitude. The air less dense. As mentioned, do check the intake tubes for leaks, typically found by looking for blue fuel stains around the upper attach point to the cylinder.
Your volts warning is set too low. 12.8-13.0 is a good low voltage setting. Any reading above that is usually indicative of a working alternator.
Vic
Vic Syracuse
Van's East Coast Representative
www.Baselegaviation.com
Old 06-12-2017, 05:36 AM
Smile High cylinder temp and voltage
Thanks for the help. I will pull the cowling and check. I'm going to change the intake clamps and tubes anyway. Vic. Thanks, I will lower the alarm.
Aircraft
RV6A owner
L19 sold
Old 06-12-2017, 07:13 AM
Toobuilder's Avatar
Considering your altitude and MP, I'm guessing you were WOT... Intake leak will not show up as an issue. The throttle blade is the biggest leak in the system. Are you FI or carb?
Also, the air is pretty rare up there.... What is your overall baffle health? Have you looked into the need for the bypass duct on #1 and #3 to get past the zero fin depth issues?
Michael Robinson
______________
RV-8 - Flying
Old 06-12-2017, 12:24 PM
F1Boss's Avatar
F1Boss F1Boss is offline
Default DOH!!
Mike is right - an intake leak is almost a non issue at full throttle. That defect shows up at idle.
I find my engine needs a bit more fuel than I thought it might at higher altitudes - lower altitudes allow for 11gph at similar power settings, so the rarified air could be your cause. I have heard this is an issue with some turbo'd engines, so don't feel too bad!
Check baffling for any leaks. And I do mean ANY. The DanH approach (Ultra Black over 9oz cloth) to baffling is the best I have seen. Atta boy Dan!
https://photos.smugmug.com/photos/i-...-nZLFSgQ-S.jpg
https://photos.smugmug.com/photos/i-...-BQFnPVV-S.jpg
Carry on!
