Old 06-08-2017, 04:28 PM
togaflyer togaflyer is offline
Default breather tube questions
Installed the breather tube. Just to make sure its right, does the bottom end of the tube sit inside and a few inches above the lower cowling. Is a whistle slot recommended (just in case the tube outlet gets blocked) and where is a good location for a whistle slot. Thanks......
Old 06-08-2017, 04:45 PM
WrightsRV7 WrightsRV7 is offline
Default lots of options for you...
I personally align it so it drips on the exhaust pipe, helps take care of some oil, rest always makes it on the belly.... With a new engine blow-by is not such a problem, so oil separator yet for this airplane. I have never used a "whistle cut" before in the pipe, but the thinking has its merits for sure. Would have be one solid block to stay put in the event of blockage by.....???? but it can/does happen, usually on planes that have sat for many years and such.
Michael Wright
Dues paid 2017
RV7 built & sold, 500h of pure joy in the air: sold
RV10 slow build & flying & loving it
