Old 06-08-2017, 09:56 AM
cderk cderk is offline
Default Riveting Bottom Skins
I've been driving myself crazy trying to figure out the best way to rivet the rivets right up against the aileron & flap attach brackets. I can't get that close with the tools (mushroom set) I have at my disposal and was wondering if there was a trick to doing it or if I needed to purchase something additional for my rivet gun. I've tried (and failed) using a long back rivet set as well.
Charlie
RV10 - #41673
http://n688cd.wordpress.com
N688CD Reserved
1980 Piper Archer II
2018 Dues Paid
Old 06-08-2017, 10:09 AM
Jasonm Jasonm is offline
I wimped out and used counter-sunk pulled rivets on mine.
Jason McKay
"Phase 1 - 05/26 - 07/02"
2017 Dues Paid
Old 06-08-2017, 10:14 AM
We used a mushroom set on those, without the retaining spring on the set. That improves the geometry.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 06-08-2017, 10:19 AM
Interesting Idea, Kyle... I'm not at home now, but thinking about it, I believe that was the issue - that retaining clip being in the way.
I'll give that a shot and if it doesn't work - the pulled rivet may be a good solution.
RV10 - #41673
N688CD Reserved
2018 Dues Paid
Old 06-08-2017, 10:26 AM
Carl Froehlich's Avatar
Take a 1/8" thick piece of aluminum perhaps 1/2" wide and 1" long. Put flush rivets in the holes and put a piece of clear tape over them so they stay in place. You will place the 1/8" thick piece of aluminum over them to rivet.
About the spot where the plate is over the flush rivets, drill a #30 hole in the plate. Slightly countersink the back side of the plate with your deburring tool. Cut a 1/8" round rivet so it is just proud of the countersink. Set the rivet such that it is flush on the countersink side.
Add a layer of clear packing tape on the bottom of the plate (it will protect the skin from scuffs).
Using a long 1/8" rouind head rivet set, drive the flush rivets with the set inserted in the head of the round rivet on the plate. Move the plate as needed to keep it over the rivet being set.
Piece of cake,
Old 06-09-2017, 12:37 PM
60av8tor 60av8tor is offline
Jon
RV-7A purchased flying - Sold 6/16
RV-10 empennage delivered 1/22/14 (325JT)
Build: http://hhav8or.blogspot.com/
Old 06-09-2017, 04:28 PM
Default Yep
That's what I used!
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
Doors - Done
On Gear
290 HP Barrett Hung
Dues Paid 2017,...Thanks DR+
Old 06-12-2017, 07:27 AM
Originally Posted by 60av8tor View Post
That's pretty interesting - never seen one of those before.
I actually tried Kyle's method, and it worked like a charm. Carl, while I'm sure you're method works well too - Kyle's took me about 10 seconds... you're looks like it would take me an hour.
-charlie
RV10 - #41673
N688CD Reserved
2018 Dues Paid
Old 06-12-2017, 09:40 AM
mgregory176 mgregory176 is offline
Default bottom skins
I used a swivel head mushroom set. Lose the retaining spring and take off the rubber shell on the side against thew flap bracket. A piece of clear packing tape will keep the primer from getting marred.
Remember you're doing it for the experience:-)
Mike Gregory RV-10
Working on the fuselage
Clayton, DE
http://www.mykitlog.com/mgregory176
I'm better at building than updating the website
