Old 06-09-2017, 07:32 AM
bret's Avatar
bret bret is offline
Did you have the elevator trim set for nose up or nose down? Kidding, glad it all worked out for ya. By chance, did you check the tong weight? we want at least 2/3 or more of the load weight forward of the axle or axles center. or else you get out of control easy like a tail dragger
2018 gladly supported
Old 06-09-2017, 07:43 AM
Never a bad idea, but it's not strictly necessary.
My post was specifically about the RV-12....
I have also move other trigear RV's on trailers (many times) with just straps on the tail and had no problems.
I have also seen RV-12's get damaged doing so. It has lighter skins (.020) and a lot less stiffening structure because of the nature of its light empty weight. Another big difference is the rather large (heavy) counterweight used to counter balance the entire stabilator.
There is no way to know ahead of time what the interaction between a particular trailers suspension, and the airplane will be. It is for this reason that I always recommend a tail prop rod.
Scott McDaniels
Hubbard, Oregon
Old 06-10-2017, 06:38 AM
Infidel's Avatar
Infidel Infidel is offline
Nothing wrong with that trailer, other than being a bit too narrow. When you think you have enough straps securing your plane, add a couple more. I always use extra in case one or more should fail.
RV-4 0320\D3G 160, Whirlwind 200GA 70".
Old 06-10-2017, 06:56 AM
AlexPeterson's Avatar
AlexPeterson AlexPeterson is offline
Originally Posted by DonFromTX View Post
I bet the trailer towing limit of that car was exceeded by a couple tons...
Alex Peterson
RV6A N66AP 1600+ hours
Maple Grove, MN
Old 06-10-2017, 07:31 AM
Flying again!'s Avatar
Flying again! Flying again! is offline
The RV12 empty weight is ~750 pounds and the trailer is around 250 so total would be just over 1000 pounds.
The new trailer is probably 1800 pounds so probably under 3000 pounds.
RV-10 N331JH 3rd owner (First flew in 2005, #15 flying)
Northwest Regional 52F
Old 06-10-2017, 10:47 AM
One way that I've used to secure an airplane fuselage to a trailer is to partially deflate the tires, wrap rope snugly around the axle and some nearby hard point on the trailer, and then bring the tires back up to pressure. It's definitely secure to the trailer then.
Old 06-10-2017, 04:02 PM
Phantom30's Avatar
Phantom30 Phantom30 is offline
Cool suggestion if you don't use racket straps...
Ric Dickison
307 (CAB) Phantom
Search and Destroy (Can
Tho RVN)
Distinguished Flying Cross Society Member
CH-47 & UH-1H "Driver"
Rotax 9 Series Service IRMT
RV-12 Kit#729 "N312RD" is now a full functioning fun machine!! Thanks Van for fulfilling my dream😎
2018 Dues Paid
Old 06-11-2017, 10:14 AM
BillL BillL is offline
The key in Dons post was the CG. A trailer with aft CG and a high mass center will go into a wag and scare the C R A P out of you. I learned this with a '47 Crosley on a trailer when I was 15. Had to drive 20 mph. Funny, that car was only 3 yrs older than me at the time.
Bill
Op Lims in hand 12-7-17
1st Flight 1-27-18
2017 Dues Paid
Old 06-11-2017, 10:15 AM
TeamFAS TeamFAS is offline
Moral of the story, avoid del rio.
Been there, done that!
Keith S.
1981 RV-3 bought 1/2017. O-320 AvMap Ultra.
2018 Dues Paid.
Old 06-11-2017, 11:53 AM
Ha, yeah, probably so. That'd be a very lightweight car hauler, but even so, the tow car probably is not rated for any towing. Good thing there is margin in designs...
Alex Peterson
Maple Grove, MN
