Old 06-06-2017, 10:05 AM
rvdave rvdave is offline
Default Rear seat belts
Vans no longer sells the 4 point rear seat belts for the 10, only 5 point. I've already removed the 5th attach point and already have the vans front belts. Anyone know the source vans was using for their belts so I can match what I already have in the front?
Dave Ford
Cadillac, Mi
Old 06-06-2017, 10:37 AM
Auburntsts's Avatar
Auburntsts Auburntsts is online now
Maybe you can sub another set of fronts for the rear. I'm going out to my hangar this afternoon and can see if they are in fact the same belts.
Todd Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 06-13-2017, 08:22 AM
Auburntsts's Avatar
Default Follow-up
So the front seat harnesses are different than the rear seat ones (I just never really noticed) to that won't work. ACS, Wicks, and Wag-Aero appear to have seatbelts & harnesses that could replace the 4-point one that Van's used to sell. The websites are particularly helpful in trying to figure out the right model so best to take a measurement a call them to get the right replacement.
Todd Stovall
PP ASEL-IA
WAR EAGLE!
Old 06-13-2017, 08:25 AM
NovaBandit's Avatar
NovaBandit NovaBandit is offline
This sounds strange to me.
I have 4 identical sets of Crow harnesses in my plane. They all fit fine. They were all ordered as 5 point harnesses, and I just didn't install the anti-sub belt.
No idea about the ones that you order from Van's though...
Ed Kranz
RV-10 N829EC - Flying
First Flight: 8/29/15
KSGS - Fleming Field, South Saint Paul, Minnesota
YouTube.com/GoodPlaneLiving
-- Build Timelapse and Travel Videos . . GoodPlaneLiving.com -- Build and Travel Blog
Old 06-13-2017, 08:48 AM
Auburntsts's Avatar
The issue is apparently matching his current belts. The online catalog only lists the 5-point and only in black. You could just drop the crotch strap but the color could still be an issue.
Todd Stovall
PP ASEL-IA
WAR EAGLE!
Old 06-13-2017, 09:29 AM
jwilbur jwilbur is offline
Where the front belts attach to the cabin top, there's a curve to the connecting bracket which doesn't exist for the rear seat belts.
-Joe Wilbur (N520LW)
Phase II - 11/2017
First flight - 8/2017
Pink slip - 7/2017
RV-10 Build Log
Old 06-13-2017, 10:14 AM
Carl Froehlich's Avatar
As already mentioned, you could just get the Van's belt and leave off the center strap.
For those building, recommend leaving in the center strap attach point. Even if you don't use it, it comes in handy as a tie down if you are hauling stuff with the rear seats out.
Don't forget to make sure your rear seats have a slot for the center strap.
I'm using Hooker belts on my planes - I'm happy with them.
Old 06-13-2017, 10:22 AM
Is that the only difference with The Vans belts? I thought there was a length difference between front and rear?
Found out from Vans the one man shop that supplied their belts is no longer so they are referring people to other vendors.
Long story short I'm ordering rear Crow harnesses and eventually will replace fronts to match.
Dave Ford
Cadillac, Mi
Old 06-13-2017, 10:37 AM
Auburntsts's Avatar
No - the front belts are a Y design in that the left and right harnesses come together into a single strap about 6-7" long before it terminates at the fitting/clip. The rear harnesses both go all the fitting/clip and do not merge beforehand and the overall harness length is shorter than the front ones.
Todd Stovall
PP ASEL-IA
WAR EAGLE!
Old 06-13-2017, 10:42 AM
I've got Crow harnesses. As Todd says the lengths are different between front and back, but the rear belts also come together and have a single attach point at the anchor - same as the front belts.
Phase II - 11/2017
Pink slip - 7/2017
RV-10 Build Log
