Old 06-05-2017, 08:55 PM
Flying again!'s Avatar
Flying again! Flying again! is offline
Default Oxygen, what size bottle?
I am looking to get an oxygen system. I am trying to decide between the Aerox 4M or 4F systems, the difference is 22 vs 33 cf bottle. The 4M is more available and cheaper.
Most of the time it will be 2-3 people on it.
Is the 22 cf for an RV-10 sufficient or do people go to 33 cf or bigger?
Thanks for any insight.
TJ
RV-10 N331JH 3rd owner (First flew in 2005, #15 flying)
Northwest Regional 52F
Old 06-05-2017, 09:08 PM
Plummit's Avatar
Plummit Plummit is offline
How are you going to refill the bottle? If it's built in with a fill port then I'd go bigger. If it's portable then smaller is easier to deal with. Also remember that FBOs will often charge a flat rate for an 02 refill, so a larger bottle gets you more for your $$$.
I've found that I need to fly 300+ mile legs to make it worth while to climb high enough to use 02. Anything shorter doesn't make it worth the climb.
~Marc
N814RV
2018 Donation made!
Old 06-05-2017, 09:27 PM
This is a portable system. I am looking at flying from DFW area to Eugene OR and thought the O2 would help over the Rockies and help my pax avoid headache. The 22 cf would be easier to stow but may need refilling on the road.
Old 06-05-2017, 09:28 PM
BobTurner BobTurner is online now
If you use oxygen conserving cannulas 22 cubic feet will last a long time. Get a pulse oxymizer while you're at it.
I use the E size cylinder. Fits nicely between the seats, on top of the center tunnel.
PS My wife used to get headaches above 10k'. Just a very small flow of O2 and no headaches. I feel better, too.
Old 06-06-2017, 06:06 AM
Auburntsts's Avatar
I asked this same question a few months ago: http://www.vansairforce.com/communit...d.php?t=148421
Consensus was the E (682L) size.
Todd Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
