Old 06-04-2017, 02:07 PM
RVdreamin RVdreamin is offline
Default Conical bend on forward skin
Guys and gals... getting ready to do the conical bend and I have read a lot, but looking for any last minute advice. What I have so far is enlarge the hole slightly, ensure hole is deburred thoroughly, and try to make the bend in one movement. Do not over bend and try to bend it back because of the stress on the aluminum. Any additional tidbits of information is welcomed.
Jimmy Black
RV-9A
Started Emp 10/9/2013 Finished 10/16/14
Wings Finished April 9, 2016
Fuselage received Sepember 12, 2016
KX59
VAF paid 2017
Old 06-05-2017, 09:29 AM
Allen Rice's Avatar
Allen Rice Allen Rice is offline
I curved that piece according to the plans and it turned out fine. 263 hours and no cracks. Take you time and sneak up on it to that you don't overbend it.
Old 06-05-2017, 09:31 AM
N941WR's Avatar
N941WR N941WR is online now
Same here, I didn't enlarge the hole, just deburred it. 760+ hours and no cracks.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 06-05-2017, 09:42 AM
Thanks guys...so I can stay with the plans, debur, and slowly work the aluminum. Once again....thanks.
Jimmy Black
RV-9A
KX59
VAF paid 2017
Old 06-05-2017, 09:50 AM
N941WR's Avatar
Just make it one smooth bend, don't do it in small increments. Remember, you will have to over bend it a little to have it stay in place. If you over or under bend it, but it is close, don't worry about it. Just put it on and rivet it in place.
Good luck.
Bill R.
SC86 - Easley, SC
Old 06-05-2017, 12:26 PM
kentlik's Avatar
kentlik kentlik is offline
I just did mine last night. By the book, but oversize drilled the little hole to .128 and deburred fully.
This is all it took for bend and then just manually massaged it into place.
Bear in mind this is on a -7.
My .02 worth
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
Old 06-05-2017, 02:28 PM
rapid_ascent rapid_ascent is offline
I was super worried about mine, but I deburred fully and did it according to the plans. I seemed to work out fine. One thing I would say is that it might be helpful to have a small radius on the piece that you clamp down. You will be bending around that piece and you don't want a sharp corner. I used a large crescent wrench to get enough torque for bending. Just go a little bit at a time. This material is tougher than you might think so it does take some effort to make the bend and it's hard to do just a little more due to the material wanting to spring back. Just don't get in a rush and it will come out fine.
Ray Tonks
2018 Donation Paid
RV-7 Fuselage in progress
* Fwd Fuselage Complete
* Mid Fuselage Complete
* Aft Fuselage Complete
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
Shop Setup - In Progress (Gathering Tools, Never Complete)
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 06-05-2017, 03:11 PM
kentlik's Avatar
Agreed. The 1" square tube I used has about .1875 radius, .250 or .375 would have been better. This is a close up of the tight bend point on mine.
[/url]
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 06-05-2017, 04:59 PM
That looks great! Will you be vacationing in Florida anytime soon 😁
Jimmy Black
RV-9A
KX59
VAF paid 2017
Old 06-05-2017, 08:04 PM
kentlik's Avatar
I don't think so...lol, but, I just set the crescent wrench in the middle, to begin with then moved it down to the tight side reefed on it, then moved it back up and reefed on it some more. I went past the 90 point by a good 20% to get it to settle at the 70 degree or so point I was left with.
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
