Old 06-03-2017, 12:03 AM
KALEWIS's Avatar
KALEWIS KALEWIS is offline
Default AP Pitch Settings
Ok, to start off, the AP is great but .. I have went thru the inflight procedures and I'm still having an issue with the capturing of altitude. The AP will blow thru the selected altitude by maybe 60 feet and then keep "oscillating" +- 40-60 feet on either side of the selected ALT. sometimes VSI up and down by up to 400fpm. Smooth air is better but not perfect. I have tried different values in the pitch settings including the VANS RV-12 presets. No play or slack in the control system. Looking for some input for data points on what pitch values seem to work best.
Airspeed, Altitude, or Brains...you need at least two
RV-12 #328
At 260 Hrs on the Hobbs
http://unicom12.blogspot.com/
Click on above for build site
Old 06-03-2017, 10:07 AM
DHeal DHeal is offline
Kyle -- My RV-12's SV altitude hold function seems to work fine using Van's pre-sets. Might you have an issue (partial blockage, loose connection, etc?) with your static system? -- David
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 635+ hours (as of May 2018)!
VAF donation through June 2018.
Old 06-03-2017, 10:40 AM
In addition, excess friction in the pitch axis can cause issues.
Scott McDaniels
Hubbard, Oregon
Old 06-03-2017, 11:04 AM
KALEWIS's Avatar
Just had the VFR / static check last week and no leaks. Scott, the controls are smooth Thru all ranges of travel, what is a good way to determine excess friction.
RV-12 #328
Old 06-03-2017, 06:59 PM
KALEWIS's Avatar
Today I reloaded skyview 15.1 with the vans presets and flew in relatively calm air. The AP captured alt well and held it within 20'. Much better than before.
RV-12 #328
