Old 05-30-2017, 05:12 PM
jcarne's Avatar
jcarne jcarne is offline
Default Trim tab hinge question E-721
I was working on my trim tab today and stumbled upon a question for you all. Let me preface this with I am probably thinking too hard about this but need someone to tell me that. As you can see in the picture below I didn't quite get the hinge positioned exactly like the drawing. My hinge was placed so that the trim tab starts with a tab/eyelet on the left; however, when you look at the drawing this first tab/eyelet should be on the elevator. The only thing that this causes is that there will be 18 tab/eyelets on the trim tab and 17 on the elevator side. The drawing actually shows 18 on the elevator and 17 on trim tab. I can't imagine how this would affect anything but maybe you do. Should I replace this hinge or slap my wrist for thinking waaaay too much into this.
trim tab hinge by Jereme Carne, on Flickr
Jereme Carne
PPL
RV-7A Emp. done
Wings mostly done
Working on Fuselage
Finish kit on order
Exempt but gladly paying!
Old 05-30-2017, 07:51 PM
johnbright's Avatar
johnbright johnbright is offline
Default Not an issue
Flip a coin. They had to draw it one way or the other.
John Bright, RV-6A 25088, at FWF
O-360, 8.5:1, vert sump, SDSEFI EM-5
Z-14 adapted for EFI, wiring and IP CAD files here
Newport News, Va
ccrawford ccrawford is offline
I can't think of any reason that would cause a problem, but a quick email to Van's support would ease your mind for sure.
// corey crawford
// rv-7a (sold)
// denver, co @ KBJC
Old 05-31-2017, 03:27 PM
jcarne's Avatar
Just as suspected Van's response is "Eyelet location is not important, build on". Thanks for the replies.
Jereme Carne
PPL
RV-7A Emp. done
Wings mostly done
Working on Fuselage
Finish kit on order
