Old 06-04-2017, 03:45 PM
DHeal DHeal is offline
Since it appears appropriate to now "think out of the box": Is your tachometer accurately reflecting engine RPM? Are you hearing and feeling these power reductions or are you just observing changes in the tachometer reading? It wouldn't be the first time that the ROTAX/SV tachometer connection was a bit erratic.
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 635+ hours (as of May 2018)!
VAF donation through June 2018.
Old 06-04-2017, 04:11 PM
Originally Posted by Azjulian View Post
its the new vented tank
the vent line terminates near the base of the filler neck, but the return line terminates right next to the fuel output on the bottom of the tank
The return line continues inside of the fuel tank and actually terminates pointing upward into the bottom of the fuel filler neck - at least that is the original design with vented cap. I'm pretty sure the return line is still routed the same way. So maybe you can look down the filler neck and verify that fuel is actually returning to the tank unimpeded. That would be good to know in your case...
Hinckley, Ohio
PPL/ASEL 1970 Sport Pilot since 2004
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 332
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 06-04-2017, 04:58 PM
RV8JD's Avatar
RV8JD RV8JD is offline
King Donald would have you powering it with "clean coal"...
And if Queen Hillary had been coronated, she wouldn't let you fly at all, given the noise and air pollution!
(Note that neither are worthy, IMHO!)
Carl N.
Arlington, WA (KAWO)
RV-8, 300 Tach Hours
(Pic 1),(Pic 2)
(Pic)
Glasflügel H-201B Standard Libelle, N564NS - Sold
Rolladen-Schneider LS1-f, N61MP - No longer owned
Old 06-04-2017, 11:14 PM
Azjulian Azjulian is offline
Jim - of course now I understand what you mean, yes I will check that tomorrow.
David - yes its the engine note change that really gets your attention and you can hear it stumbling with a bit of vibration, but I would have said the vibration is minor.
Its more of a concern of is this going to become something else....
Old 06-05-2017, 07:35 AM
alexe alexe is offline
Is it possible that one of the ignition modules is going back into "soft start" mode randomly? Would not hurt ruling that out.
Alex
Alex Erdelyi
RV-12 #120758, N912AE
Flying as of 4/28/15
Paid through December, 2018
Old 06-05-2017, 08:24 AM
"Outside the box again": Could you have messed-up one of your spark plug connectors? Or not fully seated them on the spark plugs? They are relatively fragile if handled incorrectly. Do not install them by pushing down hard on the top of the connector -- push down along the sides -- see link to CT Flier site.
http://ctflier.com/index.php?/topic/...wn/#entry57273
Old 06-05-2017, 07:46 PM
I just did some testing on my fuels lines and ran fuel for 5 mins at each point
Before mechanical fuel pump
28 gph displayed on gauge
I filled 2.4 gallons in 5 mins
Outlet of mech pump (21.4 gph displayed on gauge)
I filled 1.75gallons in 5mins
Left carb at union
(15.8 on gph displayed on gauge)
I filled 1.25 gallons in 5 mins
(I can confirm my fuel cube is accurate !)
I also check my spark plugs, all slightly off white
I check the integrity of my spark plug leads and connectors alll good.
I scoped down the fuel filler neck and I see a good spray on the return line.
I also check that I got no difference between running for 5 mins with hose off at mechanical pump and fuel cap on and off and there is no difference
Old 06-07-2017, 08:34 AM
cactusman cactusman is offline
Left carb at union
The PAP requires "at least" 1 gal in 180 seconds from the output from the gascolator.
As an aside I was finishing my "annual" and noticed one float was sinking/ borderline - and during the run-up, fuel was leaking from that carb. Another sinker - new ones are 100/pair. Hopefully that will be it.
Old 06-08-2017, 09:58 PM
Julian,
My carbs are at CPS for overhaul. When I get them back come over to GEU and you can try them.
Rich
Old 06-17-2017, 03:17 PM
Salter Salter is offline
did you ever find out what was causing the problem?
RV-14 empannage complete
wings in progress
SN# 140398
N170CS reserved
Flying out of 82J
