Old 05-29-2017, 08:28 AM
gator gator is offline
Default Glide ratio
Does anyone have a good engine out glide ratio for a RV8?
Old 05-29-2017, 05:31 PM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Default RV-6
No sure it matter that much which RV.......
but I use 1 mile per 1000 foot AGL.
Just a rule of thumb.
FYI...if you are trying to squeak out every last foot, you might consider looking into a AOA.
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1150+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 05-29-2017, 05:52 PM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
Not sure if this is the intent for the OP question, but one of the potential reasons it would be good to know is due to Foreflight's latest update that uses the glide ratio along with best glide speed to display the glide range in the form of a ring around your location on the moving map display for your airplane. It graphically displays the glide range at all times should the need arise. It is a nice new feature but it requires knowing those two performance components of your airplane in order to configure it.
RVBYSDI
Steve
RV9A
Live Long And Prosper! 🖖🏻
Old 05-29-2017, 06:46 PM
springer springer is offline
2.3 miles/1000' in my FP -8 @ 85-90 mph.
Jim
RV-4 '88-'09 Built & Sold
RV-8 Purchased
Old 05-30-2017, 05:48 PM
chuckwn's Avatar
chuckwn chuckwn is offline
Default Glide Ratio
I plan 1.3NM/1000' at 86KIAS. O-360 with C/S prop
Chuck Newman
Petaluma, CA
RV-8 N828RV
Old 05-30-2017, 06:11 PM
Default Garmin
The Garmin units take a little different data to program them.
The G3X touch we have asks for sink rate and speed. We are set up at 750'/ minute at 87 Kts. This was the mean average for Gross to as lite as we could fly. Keep in mind that they do fly 4-5 Knt. different on both ends of the weight range. Our system is all set up in Kts. not Sm./Hr. It is best to test your aircraft and get the numbers for that bird.
Hope this helps, Yours, R.E.A. III #80888
Old 05-30-2017, 06:38 PM
snopercod's Avatar
I think this is a situation where one should determine the numbers for oneself in one's own aircraft. Different props make a lot of difference.
(2018 dues paid)
Old 05-30-2017, 07:29 PM
brad walton brad walton is offline
The only way to know what your glide ratio really is, is to turn off the fan. In a real engine out situation the prop will probably continue to turn unless the engine seizes up or you slow enough to stop the prop. Your glide ratio will be less with it turning and higher glide ratio with it stopped. So you really need two glide ratios. And don't forget the effects of wind.
Alternatively, choose a lower than real number for planning purposes. Remember that unless you are as cool as John Glenn, you really won't have a lot of time to be calculating whether you can make it to that airport at 10 to 1 from your present altitude.
Old 05-30-2017, 11:34 PM
The GRT EFIS units look at your real, current rate of descent and your actual ground speed (so wind is taken care of) and show how far you can go in your current direction. Tells you right away if you can make an airport or other landing site, or not.
Old 05-31-2017, 06:49 AM
Bob, has it here. Most of the units out there now do all the figuring for you and will adjust the glide ring for wind, best runway, into the wind, surface of the needed runway, length, they will even tell you if you mite want to pass on the closest runway in order to get to a better choice. As has been said above it is best to pick a number that is on the conservative side after you have tested your aircraft in order to get your program numbers. " Don't round up- round Down". Also try to get your numbers with the aircraft as close to gross as you can. This will give you a little extra bonus distance if you have to glide at a lower weight. And just what we have found is it is not a bad idea to test you glide ring by putting an airport on the edge of the ring and pull the power, then see if you can get there safely. If not adjust you figures. As always it is not a bad idea to stay current and practice your engine out simulations. Just 2 pennies for the pot. Yours, R.E.A. III 80888
