Old 05-25-2017, 09:24 PM
Aircraft Specialty Aircraft Specialty is offline
Default Prefabricated Fuel Lines
How much interest would there be in prefab rigid fuel lines for the RV-12? There is no set time frame on this, and there would be some hurdles to overcome. It may be possible to offer rigid fuel lines that drop right into place. Some would be pre flared, and some would need one flare put on after installation.
Any thoughts from current RV-12 builders? Or any thoughts from those who already built lines and would have liked to have this option available?
If we did something like this, it would be similar to the lines we prefab for the rv-14. They would be bent with a CNC tubing bender and come ready to install.
Thanks in advance for the input.
Steve
www.aircraftspecialty.com
Please email us at aircraftspecialty@gmail.com with any questions.
Your Source for Custom CNC parts, CNC cut instrument panels and labeling, Teflon fuel/oil hoses, Headsets, and many other items for Experimental Aircraft.
Old 05-25-2017, 09:34 PM
Phantom30's Avatar
Phantom30 Phantom30 is offline
Steve
This would be especially nice from aux fuel pump back to fuel tank (with provision for tank drain and maybe a plugged 1/4" female for pressure sensor) for fuel level...the type Belite sells.
Ric Dickison
307 (CAB) Phantom
Search and Destroy (Can
Tho RVN)
Distinguished Flying Cross Society Member
CH-47 & UH-1H "Driver"
Rotax 9 Series Service IRMT
RV-12 Kit#729 "N312RD" is now a full functioning fun machine!! Thanks Van for fulfilling my dream😎
2018 Dues Paid
Old 05-25-2017, 10:53 PM
rv9builder rv9builder is offline
I think more builders would be interested if you offered a full set of all the rigid lines for the RV-12 pre-made so you wouldn't need to buy a tube bender and flaring tool.
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2018
Old 05-26-2017, 04:43 AM
I like the idea of providing a drain under the tank. That would be worth the hassle of a retrofit.
Old 05-26-2017, 05:44 AM
Mark,
I agree. However it is not physically possible in the rv-12 to have prefab lines with both flares done for every hose. The line from the valve to transducer is an example. It passes through a grommet and won't fit through the hole if both ends are pre flared. Other lines, such as from the transducer to the firewall and the tank to the pump can be pre flared on both sides.
The tubes which would require one flare to be done by the builder would be pre built, pre bent and ready to slide in place. After sliding in place, one flare would need to be made and then it would be tightened down. It would turn those tubes into a single flare event.
The bends would be made on a CNC tubing Bender and accurate within about .010 of an inch. Preliminary testing with a few lines has shown 100% repeatability and a very simple installation.
If we ended up clearing some of the logistical hurdles of this, it may be possible to have a "floating" tool that the purchase of this package would include for rental for a few days. It could move around from builder to builder.
A package like this would be something we would want to discuss with vans for Elsa reasons. (EAB would be no issue at all) However, it would have a positive effect in that it would guaranty that all critical fuel system components would fit perfectly.
Just some thoughts
Steve
Old 05-26-2017, 06:08 AM
This is one of the great things about having a plane under construction where you can put eyes on the target and really tweek things. Fortunately, Steve and Bob are building a 12 and can test fit everything right there, and NOT have to use USPS! LOL. Wish every project was like that.
Seems there are some edge distance issues with some of the bulkheads where the tubing passes through, same area as the brake lines. Steve and I have talked about this alot.
Tom
Tom Swearengen, TS Flightlines LLC
Ridgeland, SC
www.tsflightlines.com
Old 05-26-2017, 08:38 PM
waterboy2110 waterboy2110 is offline
The RV12 may be very close to the 51% rule limit. Buying prefab parts could put you over. Just something to consider - especially for those who adhere strictly to the ELSA aspect.
http://jimsrv.blogspot.com
PP - ASEL
Instrument Rating
A&P / Rotax iRMT 9 Series Maintenance
RV12 Flying.
Old 05-26-2017, 10:49 PM
KALEWIS's Avatar
KALEWIS KALEWIS is offline
There is not a 51% rule for ELSA
Airspeed, Altitude, or Brains...you need at least two
RV-12 #328
At 260 Hrs on the Hobbs
http://unicom12.blogspot.com/
Click on above for build site
Old 05-30-2017, 08:08 PM
Yes - I remember reading that when I first started building. Been a while.
PP - ASEL
Instrument Rating
RV12 Flying.
Old 05-30-2017, 09:09 PM
sf3543 sf3543 is offline
Default FYI
Rotax has a service instruction, SI-912-022, which is a cancellation of the five year replacement requirement for fuel hoses, for a lot of the 912 engines, since they came from the factory with teflon hoses.
Although it doesn't address the oil and coolant hoses, it is worth looking at and could save a lot of time and money.
Steve Formhals
RV6, RV8 (2), RV12 & RV3 about 2/3 done.
A&P, Tech Counselor & Flight Advisor
