Old 05-23-2017, 07:54 AM
RV6-KPTW RV6-KPTW is offline
Default Fuel Bracket 31-08
Hi,
I am snapping the middle tongue of these fuel brackets off with very little pressure during installation of the fuel line - 8 so far. That is not the big problem, its drilling out the blind rivets... Has anyone solved this fuel line attachment another way - adel clamp or similar?
Dennis Callaghan
- RV14 sn:140193 - empennage, wings, fuel tanks (and no leaks...), and fuse done. Procrastinating on fiberglass
- 2000+ hours on my RV6!
- Dues paid 11/2017 * 2
Old 05-23-2017, 09:13 AM
n982sx n982sx is offline
I had no issues at all. They should work very well.
This may seem obvious but do you have them in upside down?
I assumed that the top opening is meant for an optional return line because it is a smaller diameter than the bottom opening. See page 31-02
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 05-23-2017, 10:30 AM
Ron B. Ron B. is offline
I broke one of mine. I used a corner of my plans binder as the materials were similar to fabricate another. Make sure the bolt holes are large enough as I believe that is what broke mine.
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 05-24-2017, 04:00 PM
The fuel brackets are correctly oriented. The fuel line is a snudge short so pressure is being placed on the brackets sideways during installation and they just snap. I could make another line but think that a different type of mount would work just as well. I will continue to explore.
Dennis Callaghan
Old 05-25-2017, 07:05 AM
Make another---or ours are bent on a CNC. TS Flightlines and Aircraft Specialty.
Tom
Tom Swearengen, TS Flightlines LLC
Ridgeland, SC
www.tsflightlines.com
Old 05-25-2017, 07:52 AM
Tom023 Tom023 is offline
Just a plug for Tom and Steve's prefab lines. Absolute perfect fit, could not have been a spec better. Easy drop in installation and then wrestling with the tiny screws inside the ribs to secure the second half of the clips, but no broken ones.
RV14A #140083
Wings, empennage and fuselage slow builds completed
Finish kit in progress
2017 Donation
Old 05-25-2017, 08:52 PM
Aircraft Specialty Aircraft Specialty is offline
Thanks for the words. It's been a really popular package and a lot of fun to develop.
The fuselage to wing tank rigid lines are also done and fabricated. Waiting on the work bench for the first customer who wants a set at a discounted rate to beta test their fit.
Happy building,
Steve
www.aircraftspecialty.com
Please email us at aircraftspecialty@gmail.com with any questions.
Your Source for Custom CNC parts, CNC cut instrument panels and labeling, Teflon fuel/oil hoses, Headsets, and many other items for Experimental Aircraft.
