Old 05-03-2017, 12:34 PM
bkervaski's Avatar
Default Vans Parts Dept -- 1st call of shame
Well, first call of shame today to VANS parts department .. mis-drilled the forward spar #30 instead of #40 .. parts were only $50-$70 but shipping .. OUCH!
Progress: Final Assembly
Old 05-03-2017, 12:38 PM
Next time, ask here first if anyone near you just happens to be putting in a large order. You can combine them to cut shipping costs. Not real likely but sometimes you get lucky.
Old 05-03-2017, 12:59 PM
rv8bldr's Avatar
rv8bldr rv8bldr is offline
Another reason to post here is that you may not have needed to order new parts. In this case, assuming you had edge distance and so on, you could have just used AD4 rivets instead of AD3 and carried on. Only close inspection would have revealed your mistake, but I suspect everyone but an RV supernerd would not notice.
Now, that isn't a blanket statement as sometimes there may be a structural reason to use the smaller rivet/bolt etc. I'm just saying it doesn't hurt to ask first...
RV-8 C-GURV (Flying since Nov 2004) - Sold
Scratch building 4pl Bearhawk
Vice President EAA Chapter 245
Old 05-03-2017, 01:34 PM
rv8ch rv8ch is offline
Default not the last!
Bill, sorry my friend, it won't be your last! No shame in it, by the way!
Mickey Coggins
http://rv8.ch
Old 05-03-2017, 02:21 PM
Originally Posted by rv8bldr View Post
....In this case, assuming you had edge distance and so on, you could have just used AD4 rivets instead of AD3 and carried on...
Or as a refinement of that, used NAS1097 AD4 flathead rivets. They have the same head as a -3 flathead rivet but the -4 body. From the outside, they'd look the same.
Edit -- Please see post #9; I think he's right.
Last edited by David Paule : 05-03-2017 at 05:33 PM. Reason: Added line begining in "Edit"
Old 05-03-2017, 02:28 PM
BruceEicher's Avatar
BruceEicher BruceEicher is offline
I'm lucky to be based at Aurora. I take my Walk of Shame right up to the counter, they know my name. It does not stop after the build much either. Brake pads, because I taxi with too much toe pressure, baffle parts because I missed the oil cooler reinforcement mod, a new hat because you can't taxi with your head hanging out the side!
Bruce, Katie, Hana and RV-8 HulaGirl
Old 05-03-2017, 02:36 PM
JDBoston JDBoston is offline
I am curious. What spar was this?
I did the same thing to the Horiz Stab spar. I misread the plans and drilled some of the spar to spar cap holes #30. I ended up having a new spar shipped to someone who was getting a quickbuild near me. He was gracious enough to hold it for me, and they did not charge additional as it just fit in the back of the same truck.
Same deal: $120 shipping in my case for a $40 part.
Jeff
RV-14A
Status: Wings complete, Working on: Elevators. Location:MA
http://vans14a.blogspot.com/
Old 05-03-2017, 03:43 PM
BillL BillL is offline
Default Practical experience . . .
The practical result is an increasing pile of scrapped parts for a while, then as your skills improve and you begin make other things from them, the pile gets smaller until you have to order actual raw material! This may not happen on the 14 where all the pieces are actually designed and available, but it is real on a 7.
Bill
Op Lims in hand 12-7-17
1st Flight 1-27-18
2017 Dues Paid
Old 05-03-2017, 04:57 PM
I think it's not recommended to use these "oops" rivets for a whole continuous row.
Old 05-04-2017, 08:06 AM
bkervaski's Avatar
That's exactly what I did, which means the skin would have to have #30's and my OCD wouldn't let me live with it so .. new parts ordered!
