Old 05-17-2017, 05:18 AM
JDA_BTR JDA_BTR is offline
CONNEXT...
If I have a GTN625 with no Com/Nav, is a serial connection for CONNEXT needed to the PFD or MFD? If needed, which is best?
N1463 seems a good number....
Old 05-17-2017, 05:24 AM
Different drawings show different things too.
Should the GSU25 backup serial port go to the PFD, or the GTX45R? Seems the GTX is a better choice since that keeps ADSB going even on a CAN bus or PFD failure? The GTX would be getting GPS via ethernet in that mode still.
Should a serial GTN->GTX link be provided for backup even when an ethernet is cabled in?
Old 05-17-2017, 06:41 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
Originally Posted by JDA_BTR View Post
CONNEXT...
Hello JDA_BTR,
Yes, the Connext interface shown between PFD1 and the GTN on page 26-26 of the Rev. AB G3X Installation Manual is needed for the GTN 625 if you want to be able to push flight plans from the PFD1 display or from an external portable device Bluetooth connected to PFD1 to the GTN.
This is purely an optional feature and not needed to use the GTN and fly IFR if you don't want to install this RS-232 connection.
Steve
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 05-17-2017, 07:14 AM
g3xpert's Avatar
Post
Hello JDA_BTR,
The GSU 25 ADAHRS to GTX 45R transponder interface is a single RS-232 interface and is shown on page 26-22 of the Rev. AB installation manual. This interface has absolutely nothing to do with a GSU 25 backup data path.
The GSU 25 RS-232 backup data path to a display (PFD1 recommended) is shown on page 26-9. There is no such thing as a GSU 25 backup data path to a GTX.
The Ethernet interface between the GTN and GTX 45R shown on page 26-22 is a bi-directional link that both provides ADS-B+ data to the GTX 45R enabling it to provide ADS-B Out and provides ADS-B traffic/weather data from the GTX 45R to the GTN.
We don't recommend both the Ethernet interface and an RS-232 interface to get GPS data from the GTN to the GTX and haven't tested that, but it might work.
Just follow those two wiring diagrams on those two pages and you can't go wrong.
Steve
Garmin G3X Support
g3xpert@garmin.com
