Old 02-21-2017, 03:04 PM
humptybump's Avatar
If you want tungsten, then the above mentioned is the way to go. If you want something you'll enjoy at the end of the day, might I suggest THE Bucking Bar ...
- Glen, ESVA
Old 02-21-2017, 03:36 PM
xblueh2o xblueh2o is offline
I have two tungsten bars.
I refer to them as the Snickers Bar and the Brownie because they are about those sizes. I use the Snickers Bar 90% of the time.
I helped a friend build a set of T-6 wings and we used the Snickers Bar almost exclusively and on the few places I had to use an oddly shaped steel bar it was such a difference. Using Tungsten is so much easier.
Sam
RV-8 with the Showplanes Fastback conversion
Emp completed except for glass work
Wings completed except for bottom skin and glass work
Fuselage underway
N18451 reserved
Old 02-21-2017, 04:18 PM
wirejock's Avatar
wirejock wirejock is offline
Default Tungsten bar
Originally Posted by Bill Boyd View Post
Thanks, Bob and everyone else. The guy with his arm in the lightening holes will likely be me, as I think bucking is more critical than gun operation (with a mushroom set). I will use the arm protector, and I will be the one to blame if the bar is dropped and dents a top skin from the inside
There is a technique I've heard of using safety wire to fold back the skins for access while riveting, and gradually let them uncurl as the sheet is tacked down. Anyone have pics or details?
I used the same one too ever since I got it.
On the skins, I ran a string through the end hole and tethered it so it would stay open but not splayed open so far it would crease or dent. I made several wood wedges and used various thicknesses of popsicle sticks too. They were used so I could blindly use the bar and know it was oriented correctly. I also made a string lanyard to keep it from falling and denting a skin.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 02-21-2017, 08:21 PM
dave4754's Avatar
dave4754 dave4754 is offline
Default Glad I read this
I never thought of dropping the bar. With a mild arthritic prob I drop it all the time on the easy stuff.
Tungsten tungsten tungsten
I have several steel and a variety of angles on them which come in handy. Bought them all second hand.
But MY tungsten is FIRST choice every time
Dave Cobb
=VAF=2018 Donation - and a bit extra for great work!
Empennage RV 7 - Tipper
Wings complete
Fuse nearing completion, Canopy complete
AME reviewed and repaired O-320-Lyc installed
Old 02-21-2017, 08:47 PM
RV6_flyer's Avatar
Default Favorite Old and New Bucking bars
I had a favorite steel bucking bar that I used between 28 and 20 years ago that I used to build my RV-6.
My favorite bucking bar for building my RV-8 is the same weight but Tungsten.
Here are the two bucking bars. IMHO, the shape you like in bucking bars is just like headsets and underwear. There is no right or wrong, just a preferred.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Building RV-8 S/N: 80012
Old 02-22-2017, 09:13 AM
Bill Boyd's Avatar
Bill Boyd Bill Boyd is online now
Default thanks, everyone.
Bought a 5/8 x 1 x 4 tungsten off a famous auction site from an RV7A builder.
Glen, I will make it up there eventually for a cold one!
Bill Boyd
Hop-Along Aerodrome (12VA)
Old 02-22-2017, 09:50 AM
ppilotmike's Avatar
There are pictures on my weblog http://www.mykitlog.com/users/displa...=195608&row=36, but basically, I used string, tied through the lowest rivet hole and then wrapped the string around clecos farther up the structure in order to hold the skin open for me to buck the rivets in my wing. BTW, I did every one of them solo.. Have fun!
Mike Rettig
EAA Chapter 301, President www.eaa301.org
VAF Dues Current: as of 01/15/18
RV-10 (41PX Reserved) Fuselage
http://www.mykitlog.com/mikrettig
Old 02-22-2017, 02:08 PM
Bill Boyd's Avatar
That was the general idea. Mike. Thanks for the link to your pix. Self-explanatory.
Bill Boyd
Old 06-06-2017, 10:25 PM
FL-flyer's Avatar
FL-flyer FL-flyer is offline
Hey guys,
This was a great thread on tungsten bucking bars. I think i am going to order one tomorrow. It looks like the majority of you are using 5/8" x 1" x 4" bar, but isn't the 4" length too much for this bar to fit squarely into rib flanges?
Casey M
Sarasota, FL
EAA 180
Starting on empennage section - August 2016
Old 06-06-2017, 11:23 PM
tgmillso tgmillso is offline
One end of the bar has a slight angle on it, so you can buck the rivets on one flange and still clear the flange below. Once you have two skins on, the bar is so dense that you can just hold it sideways and still buck rivets well. It's the one to get for sure, and the use of it will be very intuitive.
Tom.
