Old 05-08-2017, 12:17 AM
greghughespdx greghughespdx is offline
I had two MG's. With Lucas electrics you need a spare car!
I had a MGB for years. They say you need three (of any older British car). One to drive, one to look at, and one for parts!
(with apologies to our UK friends!)
Building RV-8A as of September 2014 (N88VX reserved)
VAF build thread - Flickr project photo album - Project Facebook page
Flying a Warrior PA28-151 and a few RVs here and there
TeenFlight program mentor
Exempt, but paid anyhow
Hillsboro, Oregon (EAA 105)
Old 05-08-2017, 06:01 AM
Mel's Avatar
Mel Mel is offline
Lucas is now selling vacuum cleaners. Only Lucas product ever that doesn't "suck"!
A&P/EAA Tech Counselor/Flight Advisor
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 06-13-2017, 03:05 PM
Piper J3 Piper J3 is online now
Yesterday my electric fuel pump did not start when the master switch was turned on. I have my Dynon D-180 set to start up on the EMS screen. One of the first items on my Before Engine Start Checklist is to verify ~ 2psi fuel pressure from the electric pump. Once the engine starts I check for ~ 5psi fuel pressure which then tells me that both the electric and engine-driven pumps are working.
So yesterday I had no pressure indication from the electric pump with 244TT. VAF to the rescue… and first thing to try is to give the electric pump a smart tap to dislodge any debris that may be inhibiting the internal solenoid piston. I taped the top of the pump with the handle of a #2 Phillips-head screwdriver and it fired right up. Looks like it might be a good fix.
I now have 40 hours flight time since I took the fuel tank apart for the strengthening SB and I can only guess that some debris from the scraping/cleaning/reassembly found its way past the finger screen at the discharge fitting on the bottom of the tank.
I made an access hole in the baggage floor access plate so I can tap the pump should the need arise without removing any screws. Carpeting on the floor of the baggage compartment will cover the hole and prevent anything loose from finding its way into the belly of the plane. I cut a piece of aluminum tubing to use as a tool to tap the pump. This will be kept in a small tool box that stays with the plane.
Hinckley, Ohio
PPL/ASEL 1970 Sport Pilot since 2004
RV-12 E-LSA #120058 AWC 7/12 Bought Flying 10/15 with 48TT - Hobbs now 317
LSRM-A Certificate 2016
Old 06-13-2017, 08:02 PM
Mel, that was one of the funniest posts I've seen on the blog! A guy (fellow MGB owner) once told me that terror is sitting in a space craft on the launch pad and seeing a placard on the instrument panel that says "Electrics by Lucas"!😱
Old 06-13-2017, 09:15 PM
Aggie78 Aggie78 is offline
Default I gave up on British motorcars....
Originally Posted by sirlegin View Post
Same can be applied to my old TR7
When my brother-in-law's old Triumph Spitfire quit running once, I seemed to recall that the fix was buying a new taillight bulb.
Seems the ground for the ignition circuit was somehow wired through it?
When the bulb burned out, the car quit running!
All this was back in the Miocene Era...Back in the days when there were "Foreign Car Parts" houses and countermen staffing them that knew what they were talking about...He gave us the point out vs making 10 bucks off a couple of broke college kids about to spend our beer money on a new coil...Good luck finding someone like that today!
Upside to ownership: You got in great shape pushing the thing down the road to where it could be worked on...
Rob Schroer
T67-Hicks Airport, Texas
Old 06-14-2017, 08:57 AM
rongawer's Avatar
rongawer rongawer is offline
Default Standby Fuel Pump
At the risk of stating the obvious, including a standby fuel pump would seem to be a good thing.
Looking into the baggage compartment from behind
Fine fuel filter on top, but primary and standby fuel pumps below.
Ron Gawer
- RV12, N975G, SN 120840, Build in progress...finishing up.
- BE58, N1975G, stimulating the economy one flight at a time.
