Old 11-10-2016, 04:40 PM
Gandalf Gandalf is offline
Default 46-01 Cooling Shroud Deleted
Having just installed the cooling shroud, I note that it has been deleted.
http://www.vansaircraft.com/public/service-rv12.htm
Update 46 10-26-2016
Old 11-10-2016, 07:57 PM
LittleJoeA LittleJoeA is offline
I have it cut out, fitted, clecoed and ready for fiberglass. Now I will remove it and fill the holes. A lot of time invested at this point, but if it's not needed there is no sense spending more time.
Joe Arluck
Livermore, CA
RV-12, S/N 120419
Empennage/Tailcone finished
Wings finished
Most of Finishing Kit finished
"It's sitting on the Landing Gear"
Engine mostly installed
Avionics Kit in Hand
Currently fitting wings
Paid 2018
Old 11-10-2016, 10:14 PM
Hi Joe.. Do me a favor and call VANs first. I only note that the cooling shroud over the engine fins has been deleted on new power plant builds. I would think that if the cooling shroud is left in place over the engine fins it would trap heat without a properly installed forced air supply.
Jeff
Old 11-10-2016, 11:36 PM
Jeff,
Will Do. Thanks
Joe
Joe Arluck
Livermore, CA
RV-12, S/N 120419
Wings finished
Paid 2018
Old 03-21-2017, 01:52 PM
magiccarpet's Avatar
magiccarpet magiccarpet is offline
Default Shroud or no shroud
My engine kit was delivered with the FF-1207 cooling shroud. Then in the meanwhile Van's got rid of it in their revised section 46. So I have the option wheter to install it or not.
If it does not make any real difference in cooling I d'rather skip to install it due to additional weight, easier access to the engine and to comply with the latest KAI rev.
So I am looking for pros and cons. and experience from pilots who fly the -12 without the shroud.
What I neither have found so far is an explanation why that shroud has become obsolete.
If anybody can enlight me about that, I very much appreciate it.
Chris, RV-12 HB-YSC
Final assembly
Facebook: http://www.facebook.com/magic.carpet.aviation
12-Town:http://12town.com/profile/Chris
=VAF= dues paid for 2018
Old 03-21-2017, 04:45 PM
Jamesey Jamesey is offline
Default A bit confusing
At the same stage. Vans have obviously done a cut and paste with the new section 46. Remove the ignition modules for example. Cannot see how to complete this without removing the manifold which is no longer called for. The drawings have not changed from the old version so no clues there. Am I missing something?
Old 03-22-2017, 10:12 AM
John-G John-G is offline
Folks Ö here is my take on the issue.
Without knowing if there is a significant reason for Vanís decision like hot spots on the cylinders, ect, Ö. Iím guessing the added benefit of having the cooling shroud versus the potential issues involved by Vanís requiring builders to remove the upper portion of the Rotax engine to install the shroud may have been a contributing factor in Vanís decision. Not to mention perhaps even behind the scenes Rotax warranty issues.
Cumulatively, there are many thousands of hours on RV-12ís with the cooling shroud in place without any adverse engine issues being reported that we are aware of Ö so that is a known entity. That said, if I had the parts, I would install them.
Another thought comes to mind Ö with the shroud off is there more of a potential for the rising heat from the cylinder fins to contribute to vapor lock at the carbs or fuel lines? Ö especially after a short refueling stop or restroom break on hot days? I would think the shroud over the cylinders helps mitigate the negative effects of rising heat from the cylinders heating the fuel.
John
www.dogaviation.com
Now Flying!!
Dues paid until September 2018
Old 03-22-2017, 11:35 AM
Phantom30's Avatar
Phantom30 Phantom30 is offline
Interesting point regarding our "auto-gas preferred " engines...the cooling fairing being a heat shield below carb lines/bowls. Would like to hear from builders that haven't installed them who fly out of higher heat areas.
Ric Dickison
307 (CAB) Phantom
Search and Destroy (Can
Tho RVN)
Distinguished Flying Cross Society Member
CH-47 & UH-1H "Driver"
Rotax 9 Series Service IRMT
RV-12 Kit#729 "N312RD" is now a full functioning fun machine!! Thanks Van for fulfilling my dream😎
2018 Dues Paid
Old 03-22-2017, 01:52 PM
Default That's what Van's says
Thanks a lot for your inputs on that. Interesting thought about potential vapor locks. I also wonder what Synergy does in their serial production.
Anyhow, here's the answer from mothership to my question why the shroud has become obsolete.
Further testing showed insufficient benefit from the shroud so we eliminated it to keep the kit cost down, and reduce the work required.
I am still curious to get pireps using that setting.
Chris, RV-12 HB-YSC
Final assembly
Old 03-22-2017, 03:20 PM
The carb. float bowls already have a metal heat shield below them, called a drip tray.
The carbs are not above the aft cylinders so the shroud likely has little effect in shielding them while on the ground.
Scott McDaniels
Hubbard, Oregon
