Old 09-25-2015, 10:01 AM
Toobuilder's Avatar
The general comments of caution are appreciated and I may even instrument the engine, mount and airframe to see how much vibration is passing through the isolators. That said, there is a wide variety of "stiffer" engine isolators available for aerobatic aircraft - and in some cases, the very stiff "compression" side of the Lord isolators are recomended by Lord in all 8 locations for the hard core acro airplanes. And finally, solid polyurethane isolators are available from Spruce today for conical engines, so I'm not going too far off the reservation with this experiment.
Michael Robinson
______________
RV-8 - Flying
PA-20-inspired "family truckster" -in work
Old 09-25-2015, 10:47 AM
grubbat's Avatar
grubbat grubbat is offline
Default Conical poly
I had poly conical in my -3 and you could feel every engine quirk. It wasnt bad but there was a difference. I did notice more vibration on the panel.
I wonder if you could machine out a 1" core and use a softer rubber material there and poly on the rest?
Craig
RV-3 Sold
RV-6a Sold
RV-9 IO-360 CS, Flying
1967 Twin Comanche C/R, Flying......
Old 09-25-2015, 01:15 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Of course it works and sag is much reduced. With everything, there are usually tradeoffs and it depends what's most important to you. Only time will tell if the avionics or airframe suffers more problems or not. Engine sag is annoying and ugly for sure.
Turbo Subaru EJ22, Marcotte M-300, IVO, RV6A C-GVZX flying from CYBW since 2003- 418.1 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi.htm
Old 09-25-2015, 01:48 PM
Toobuilder's Avatar
Originally Posted by grubbat View Post
...I wonder if you could machine out a 1" core and use a softer rubber material there and poly on the rest?
I am contemplating machining an air gap between the spacer and the body of the poly to try emulate the action of the Lord mounts, but I have to balance that with the shear loads on the remaining material. It will be an iterative process, for sure.
Michael Robinson
______________
RV-8 - Flying
Old 09-28-2015, 07:31 PM
Radioflyer Radioflyer is offline
Why not switch to hard rubber. More compliant. If you can't source a "rod" to cut the shape from, maybe laminated sheet circles would work? Just an idea.
Old 09-28-2015, 07:40 PM
Toobuilder's Avatar
Laminated sheet might work if we were only dealing with compression loads, but the mounts have to deal with shear as well. Anyway, rubber is more compliant, but has a memory. Poly can handle billions of cycles and will retain original shape. That's the theory, anyway.
Flew it yesterday and hardly notice the vibration anymore. It's really not that bad unless you jump from rubber directly to poly and have the opportunity to compare the two.
Michael Robinson
______________
RV-8 - Flying
Old 09-28-2015, 09:26 PM
spark68 spark68 is offline
Default Poly springs
There are different density polyurethane springs available too. We use them in the metal stamping industry for springs. They are large cylinder shapes, look like they could work for your raw material size. Maybe I can find someone at work to give me a source. Mitsumi comes to mind.
Mark Curley
RV-6 (under construction)
dues paid 2018
Old 09-29-2015, 06:05 AM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is online now
Default Urethane options
Urethane can be cast from liqued components just like epoxy. The durometer can be varied similar to to selecting slow and fast catalyst. Since tool builder has a lathe, simple molds can be formed for the task.
I did this for a Cont A40 mount to avoid the crude rubber sheet stock used in 1936. Just another option if you want to tinker.
Larry DeCamp
RV-3B flying
RV-4 fastback project in the shop
Clinton, IN
Old 09-29-2015, 07:22 AM
rv6ejguy's Avatar
This is what I did on mine. I machined the molds allowing for contraction, specified the durometer and they turned out great.
Old 09-29-2015, 07:54 AM
Toobuilder's Avatar
Ross (and Larry)
You poured the mounts yourself, or had them cast? I'm aware that they can be built to spec, but the idea of building a mold and pouring them at home is intriguing. How dimensionally accurate are they (contracion)?
Michael Robinson
______________
RV-8 - Flying
