Old 08-26-2015, 11:40 AM
Toobuilder's Avatar
Question Polyurethane For Dynafocal Isloators?
Looking at a spare polyurethane automotive suspension bushing the other day and I thought I could chuck it in the lathe and turn out a dimensionally accurate replica of the Lord mounts on my Rocket pretty easily. Yes, it's a lot harder than the Lord mount, but if the vibe and shaking is acceptable, it should last about forever and will never sag.
Has anyone done this?
If so, any comments pro/con?
Michael Robinson
______________
RV-8 - Flying
Old 09-20-2015, 08:41 AM
Toobuilder's Avatar
OK no experience with this anywhere on the web that I can find, so I did it myself. I purchased a 24 x 3 inch stick of polyurethane for about $100 bucks (2 complete airplanes worth) and put my lathe to work on some mount pucks, spacers and washers.
Currently, they are installed on the upper ears only just until I decide if they are acceptable. After installation and ground test yesterday, I went ahead and flew it for about 30 minutes. As expected, it transmits more movement to the airframe, but I'm undecided if it is "too much". It is certainly not going to hurt any structure or instrumentation- it's just a bit more than I'm used to with this airplane. In fact, I've flown 4 banger Lycomings with similar vibration levels.
Overall I expect that these mounts will completely eliminate the "shear sag" that the rubber mounts have and last the life of the airframe, at the expense of being stiffer overall and very sensitive to temperature. These warmed up on yesterdays flight and got smoother, so I expect a cold start after sitting overnight in sub zero temps is going to be very rough for a while. We shall see. I'll keep you all posted.
Michael Robinson
______________
RV-8 - Flying
Old 09-24-2015, 07:27 AM
Radioflyer Radioflyer is offline
Michael, thanks immensely for doing the experiment. I will be on the lookout for further reports. The standard Lord or Barry rubber mounts are way too expensive, even the generic aircraft spruce ones and I've often thought about trying to find cheaper substitutes. I wonder if it is possible to do the same (I.e., machine or fabricate) mounts from a stick or stack of high Shore number rubber?
Old 09-24-2015, 06:39 PM
Toobuilder's Avatar
It will be a couple weeks before the second set goes in but I will let you know how it goes of course.
I would like to point out that while the Lord (and equivalent) isolators are way more expensive than I'd like to see, they are quite a bit more sophisticated than what I'm doing here. Lords hang the entire engine on a rubber bellows which has the conflicting requirements of allowing a lot of engine movement, but keeping that same heavy lump located in one position in space. They need to produce consistent results over a wide range of temperatures, to boot.
All I'm doing is building oversized conical mounts, and they only have the requirement of keeping the engine located (forever, I hope), and provide an "acceptable" level of vibration isolation. I have some experimenting to do, but I doubt these will ever be acceptable for a family cruiser like a -10. OTOH, it will likely be "OK" for a hot rod like a Rocket, but a slam dunk for a hard core acro machine which only flies for 45 minutes at a time. Time will tell.
Michael Robinson
______________
RV-8 - Flying
Old 09-24-2015, 07:05 PM
Mel's Avatar
Mel Mel is online now
One thing you should consider is that additional vibration transmitted to the airframe is also transmitted to your instruments and avionics.
There's more than a good chance that their life will be shortened considerably.
A&P/EAA Tech Counselor/Flight Advisor
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 09-24-2015, 08:01 PM
Since the real isolators are designed for a certain stiffness, at least measure the deflection required to compress them at some arbitrary force, and attempt to match that with your new ones. Just messing around by feel is not going to do the job.
Of course the real isolators have considerably more engineering poured into them than just that, but at least you'll get in the ball park.
Old 09-24-2015, 08:46 PM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
The stock-style rubber units have a steel spacer in the center which bottoms out as the rubber is compressed during assembly and allows the bolt to be properly torqued. Do you still have that same mechanism in place, or are you simply torquing against the polyurethane? If the former, I'd guess you had to do a trial-and-error method of machining a little plastic away at a time until the spacer bottomed, since I'd expect polyurethane at ~3" diameter to be too stiff to compress under only a 7/16" bolt torque load. Nonetheless, interesting experiment!
Old 09-24-2015, 08:53 PM
David-aviator David-aviator is offline
It is an interesting experiment.
Seems to me urethane is not good at high temps, at least the urethan foam used in fiber glass construction melted easy.
Perhaps the density of this product makes it ok at engine compartment temps.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
I'm in, dues paid 2018 This place is worth it!
Old 09-24-2015, 09:33 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
I had custom polyurethane bushings poured for my Subaru installation at a low durometer and have used them since day one. Almost 400 hours now. I wouldn't do it again. They work on mine only because the Sube has way less vibration than a Lycoming but if you look at the characteristics of the material vs. rubber at higher frequencies (I didn't research that first), it reacts very differently and may not be the best idea.
Turbo Subaru EJ22, Marcotte M-300, IVO, RV6A C-GVZX flying from CYBW since 2003- 420 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi.htm
Old 09-25-2015, 03:11 AM
Toobuilder's Avatar
I have the spacer - see post #2. It's machined about 0.010 short of the static stack height and definately bottoms under the torque load. I can feel this sharp increase as the poly compresses down to the spacer.
Michael Robinson
______________
RV-8 - Flying
