Old 01-30-2015, 04:46 AM
Renzo Corvetta Renzo Corvetta is offline
Default RV-14 side view, top view
Can someone help me with detailed drawings (top view, side view) of the 14 to start playing with paint schemes? There is something on the RV14 Vans website yet is quite crude.
Thanks!
Renzo Corvetta
Italy
Building an RV14
Old 01-31-2015, 02:29 AM
dcpearso dcpearso is offline
I am in the process of getting a 3d model done of the 14 so I can play around with it. I will let you know when it's done and share it around.
Old 01-31-2015, 02:52 AM
Great! Thank you
Renzo Corvetta
Italy
Building an RV14
Old 01-31-2015, 02:53 AM
control control is offline
Sound super!
IT would be great to have a 3D model that you can paint and then import into FSX or X-plane to get a good look at it from any angle.
RV-14 kit #140138
working on the finish kit
wings, tail kit and fuselage basically done
Http://magnusrv.blogspot.se
Old 02-10-2015, 06:23 PM
progress being made on the 3d model.
Old 02-10-2015, 08:55 PM
Debovsky's Avatar
Debovsky Debovsky is offline
Default RV-14 line drawing
I've made/reworked a line drawing from a CAD file supplied by Van's. I'm using Autocad to generate a PDF file that I convert to a PNG file afterward. This allows for replication of identical drawings having exact same dimensions from one another.
The file I'm generating produces a very high resolution print if you have the mean to print it out to full size (44in x 34in or 6750 x 8750 pixels). Otherwise, you can print out at a reduced scale if necessary. If you PM me, I can send you two files showing side and top view. I can send in PDF format or PNG.
As an example, see below a down sized file of one of the paint scheme I've created. It is 1600 x 700 pixel
Marc R. Beauvais
Wing kit #140070
Wings assembly underway
C-FOOT (reserved)
(QC) CANADA (Homebase CYVO)
http://www.mykitlog.com/Debovsky/
" Resistance, is futile "
Old 02-11-2015, 05:45 PM
jeffw@sc47's Avatar
jeffw@sc47 jeffw@sc47 is offline
3D model looks like a SketchUp creation. does SketchUp provide a tool to apply bounded color layers to the model's 3d surface?
Jeff Warren
Simpsonville, SC (SC47)
1946 Bellanca Cruisair 14-13-2 (71 YRS OLD 8/15/17)
RV14A (N14ZT), Ser#140195
Start 10/11/14
IO-390 Lyc Tbolt / CS Hartzell
Dues paid 12/1/17 (USArmy 2/67-2/70)
www.mykitlog.com/jeffw@sc47
Old 05-09-2017, 11:38 AM
Logan Logan is offline
Default Any models available?
Hi. Has anyone completed and shared any 3D models for the -14? I'd like to get a copy, as I tried to build one and found it way over my head! Thanks.
Logan Dent
RV-14A in progress
Empennage complete(-ish)
QB wings and Fuse in progress
Old 05-09-2017, 05:25 PM
salto salto is offline
Very creative Marc. 👍
Kit 140241
Tail Feathers done
Fuselage kit completed.
wings almost complete.
Flaps and ailerons done.
Canopy next. Phew!
Old 05-11-2017, 02:56 PM
Polar Polar is offline
Check with Username: Notorious Nate. He's been working on a paint scheme for my 14 for awhile, and has made all the 2D views and a 3D model. He does great work, shoot him a PM.
