Go Back   VAF Forums > Model Specific > RV-4
Old 06-16-2014, 10:20 AM
chris mitchell chris mitchell is offline
Default RV-4 rudder pedals - deliberate misalignment??
Just completing the firewall and I see that the inner and outer pivots for the pedals are on different axes - ie, misaligned by 9/16", with teh outer pivot point further forward. I have looked hard, studied the arrangement, thought about it, and cannot see what benefit there is - though there is plenty of friction and will be extra wear in time. I note that Tom Martin added an extra bracket to the inboard pivot - which I think is just visible in one of Ax-O's photos. I am inclined to make this modification, but also to modify the outer pivot so that the outer one is aligned with the inner one - seems a much more satisfactory solution to me unless someone can see a problem or tell what what the advantage is of the arrangement per plans??
Chris
Chris Mitchell
Repeat offender;
RV-8, QB, built, flown 150 hours, sold;
RV-4 - attempted repair, rebuild and remediation - abandoned and junked ;
RV-4 fuselage and wing kits - both at QB stage;
2015-2018 dues paid!
Old 06-16-2014, 10:24 AM
Default It has to be for tunnel geometry
When I built mine, I had same thought, but Van is a smart guy! The geometry of the tunnel between your legs mandates the offset hinge points,as it gets wider going AFT and everything just fits...build it per plans. It is un-noticable when operating them.
Bill E.
RV-4/N76WE
41 Aeronca 65TC Defender
8A7 / Advance NC
Old 06-16-2014, 01:45 PM
Default Hmm take your point
about the tunnel - and of course we can't move the tunnel because of the mounting points for the engine mount frame - but that's definitely a bodge!! The holes I lovingly drilled undersize and reamed on a drill press to ensure they were round, normal to the surface of the bracket, should in fact either be sloppy - likely they will get sloppy pretty quickly - or on the slant. Eeek. Alternatively bend the brackets some. Or just do it like the plans say and accept that it works just fine and has done for a couple of decades!
Build on!
Chris
Chris Mitchell
Repeat offender;
Old 06-16-2014, 02:09 PM
AX-O's Avatar
AX-O AX-O is offline
I also thought that was weird and did not like the design. I figure it had to do with the tunnel versus the pedal swing. I decided to add the extra bracket and keep the rest of the design per Vans. I am sure there is a reason for it.
Axel
RV-4 fastback thread and Pics
West Coast Ravens
VAF 2018 paid VAF 704
The information that I post is just that; information and my own personal experiences. You need to weight out the pros and cons and make up your own mind/decisions. The pictures posted may not show the final stage or configuration. Build at your own risk.
Old 06-16-2014, 03:40 PM
foka4 foka4 is offline
Default Another variation
I don't have pics, but I bought some really long AN bolts that pass all the way from the inner bracket to the outer bracket to prevent binding, racking and uneven wear of the bolts. Don't know if it was necessary, but it works great.
I thought this part of the RV4 design was less elegant than the rest of the design.
M
Old 06-16-2014, 10:13 PM
Sodbuster Sodbuster is offline
Default RV4 rudder pedals
The mounting is necessary to make the rudder pedals swing parallel to the center tunnel. I cut the pedal frames and put a twist in them; then welded them back together. This makes the pedals set parallel to each other but swing parallel to the tunnel. Jim Winings 317/718-3415 (Another fast back 4)
Old 07-12-2014, 07:10 PM
skiandtom skiandtom is offline
My plans included drawings for building outboard rudder pedal pivots.
Old 05-25-2017, 10:02 AM
acam37's Avatar
acam37 acam37 is offline
I'm installing the rudder pedals on my new project. I had a quick question about the alignment? They pivet very nicely without any binding but looking down on them they are not square with the fuselage or each other. From what I've read, this is by design. Is this correct?
Arlie Conner
RV-4 (N124TT) Sold
RV-8 (N269CP) Sold
RV-4 (N684ML) under construction
KOCH Nacogdoches
Old 05-25-2017, 01:06 PM
Default YEP..they are supposed to be
They will travel parallel to the tunnel more so than the fuselage side skin, thus keeping them from hitting the tunnel, as they would if they come straight FOR/AFT.
Bill E.
RV-4/N76WE
8A7 / Advance NC
Old 05-25-2017, 01:08 PM
AX-O's Avatar
Originally Posted by acam37 View Post
..........but looking down on them they are not square with the fuselage or each other. From what I've read, this is by design. Is this correct?
that is correct. Don't forget the service bulletin for the pedals while you are working on this.
Axel
West Coast Ravens
