Old 01-16-2014, 03:35 PM
digidocs's Avatar
digidocs digidocs is offline
Default When to rivet cockpit floor?
Hi there,
Near the end of Section 29, Van's prompts you to permanently install the forward cockpit floors. Is now a good time to do that or should I wait?
I don't think that there will be any additional insulation or wires in that area.
Thanks for the advice,
David
Old 01-16-2014, 05:17 PM
stamper stamper is offline
You can put it down but keep in mind if you want to insulate the floor now is the time.
Old 01-17-2014, 06:56 AM
digidocs's Avatar
Question
No more insulation to do --- in it goes!
Thanks for the help.
David
Old 01-17-2014, 11:40 AM
jwilbur jwilbur is offline
Originally Posted by digidocs View Post
.... Near the end of Section 29 ...
I didn't realize there was an end to section 29.
-Joe Wilbur (N520LW)
Phase II - 11/2017
First flight - 8/2017
Pink slip - 7/2017
RV-10 Build Log
Old 01-17-2014, 11:50 AM
longranger's Avatar
longranger longranger is offline
Now THAT's funny!
Miles (VAF# 1238, Paid up as of 12/2016)
RV-7 TU 904KM (reserved)
Wings Fitted and Finish Kit on order
Construction Log
Picasa: Empennage Album, Wings Album, Fuselage Album
1955 Cessna 170B flying since 1982
'To get something you never had, you have to do something you never did.' -Unk.
Old 01-17-2014, 12:03 PM
rleffler's Avatar
rleffler rleffler is offline
The only areas that you may want to delay or customize access is the rear seat and baggage area.
A fair number of people mount antennas under the rear seat. I ended up making an access panel (after the fact) when I had to troubleshot an antenna issue.
The other area is to access the bolt for the steps. Nuts have become less tight and needed to be re-tighten. This doesn't seem to impact everyone, but it does appear to happen frequently. I installed some aluminum pieces that Bob Newman (TCW Technologies) made which appear to minimize that issue due to having something solid to minimize the flexing.
I also held off riveting the upper fuselage assembly to give me more time to work on the wiring harness. It's much easier to wire on the bench that in the plane.
bob
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 06-18-2017, 01:40 PM
Freightdawg's Avatar
Freightdawg Freightdawg is offline
Talking Not what I was searching for...
...but thanks for the laugh. I needed that. (I turned the air blue wrestling the rear floor pans into place.)
Jeff Rich
RV-10 empennage done for now. Wings done for now. Working on the (SB) fuse (Section 43: Cabin Cover)
Finishing Kit is here! Check for the motor cleared
N313KC reserved
In the garage for now, KJVY this summer
Old 06-26-2017, 07:44 AM
WrightsRV7 WrightsRV7 is offline
Default floor access...
I will second Bob Leffler's suggestion for access in particular through the baggage floor. I ran one 3/4" plastic conduit under the rear seats and called it quits for "access" there. I have the two 3/4" plastic grommets on each side installed that handled my battery/static tube/AP/Txpder/trim/misc wires to the back, I did find the extra tube handy for the GPS antenna RG400 wire (Garmin GTN650). However, if you add/install an inspection plate on the left and right sides above and a little forward of the step (baggage compartment), you really have access to under the seats as well, especially easily if you have some conduit or just holes with grommets installed BEFORE riveting on the floors. I also very much like the idea of access to the step mounting bolt etc...... Just as a FYI, I made the panel on the right-side of the baggage compartment removable (add nut plates on flooring & side angle) and this provides access from front to the rear, should I ever need that one last wire run to the back that I forgot...... Another comment, since you are really planning how to get wires to the back with access, I used the right side 3/4" angle/ longeron as a SECONDARY ground to the front (engine/firewall), some have run large copper wire, some nothing at all. I can & will just say, my single PC928 in the back cranks my heavy Hartzell prop beautifully on the hottest day of a hot start. And at KIYK these days at 110+ deg F, I understand a hot start for the engine and me in the cockpit!
Michael Wright
Dues paid 2017
RV7 built & sold, 500h of pure joy in the air: sold
RV10 slow build & flying & loving it
