Old 03-06-2017, 10:00 PM
Looking great, John! Can't wait to see the wings in that extra-fancy wing stand.
Doug
RV-9A "slider"
Flew to Osh in 2017!
Tail number N427DK
Donation made for 2018
Old 03-18-2017, 11:34 PM
Default Wings-ribs
These are my wing ribs all deburred.
The two yellow spools are the sandpaper I used for deburring the holes and flange edges. I also used just a loose sheet of 220 grit pinched between my fingers for the long straight flanges. The abrasive spools were a 1/16" rope and a 1/4" flat ribbon. This worked really well. I probably used 25% of a 25 foot roll. Many of the rib flanges were fairly well deburred already, so it didn't take much more for me to be satisfied. The lightening holes needed the most effort.
I also built the rib flange forming thing-a-ma-gig sitting on the table. It forms the flanges to the perfect 90 degrees to the rib web. It works very well. However, when I tried it out, I grabbed a nose rib and looked at the flange. It measured almost perfect without me having to touch it. Then I looked at the center rib, seems perfect too. Did I spend half a day and $20 on this thing for nothing? I will finish up checking the flange angles tonight. But I will probably be too embarrassed to tell anyone how useful, or useless, this tool was. It is well worth the effort to construct for the flanges on the tail ribs, wish I had it then. But I hope I never have to rebuild the tail feathers. I am very grateful Vans aligned the flanges on these ribs; saved a ton of work.
Also in the picture are the mods I plan to make to the ribs. I talked to Van's Aircraft support on Friday and they said what I had planned seemed reasonable. If you wish to follow my example, please check with Van's yourself. So here is my plan: for the nose rib, I will enlarge the internal fuel vent hole from 1/4" to 1/2". (This is not the hole the vent tube goes thru, but the one that will be at the high point when filling the tanks.) The stock hole seems really small to me, and others have complained the tanks are slow to fill. I don't plan on doing aerobatics, nor uncoordinated flight (who does?), so I am not worried if these enlarged holes cause the fuel to slosh around a little more. For the main rib, I plan to follow the supplemental instructions on the Van's Aircraft site and add a hole in the main web to the right of the first lightening hole in the picture. This will be 3/4" per the supplemental instructions. Also the RV9 plans say it is permissible to enlarge the forward tooling hole to 1/2". But the same Van's supplement says the RV7 and 8 can enlarge this to 5/8". I will follow the 9 plans and only enlarge to 1/2 ".
Lastly in the picture, behind the table, are the wings stands for the spars. I plan to build both wings at once. These stands are a God send. Thank you to the builder Billy who provided them.
So that is my plan. Onward and upward, (well not yet anyway) :-(
Thank you
John S
Fuselage started
Old 05-02-2017, 06:48 PM
Default Harvesting Clecos for Wings
So have started building the wings. Not much to write about as everything started out well and went as per plans. Of course as I was saying this to myself I did find some "knowledge" was needed, and a few bandages. But I am getting ahead of myself.
Here is the bountiful harvest of clecos. And a warning. Just go ahead and order a thousand 3/32 clecos; if ordered all at once, there is a break in the price at a thousand, and the shipping is only one time. I am on my fourth cleco order; UPS is making bucks on shipping. Here is my cleco farm, ready for harvest. I am doing both wings at the same time, so this is only one of the two wings, Yes I ran out of clecos; the rest are coming in time for the tanks. Total clecos count will be slightly more than a thousand.
The main skins went on as per plans, no real drama, except I had a few holes in the rear spar where the holes in the rib, spar and skin didn't line up. Next time I need to make sure the rib holes line up with the rear spar during the rib to rear spar riveting. It is kind of tough to do it after the rib to spar rivets are in.
I didn't quite follow the plans when I put the J stringers in. I indeed drilled through my finger, even though the plans say "be careful don't drill through your finger". Speaking of J stringers, I had to make the short one a half inch longer to pick up the third rivet hole in the skin.
The leading edge ribs are notoriously for being hard to fit into the skin. During my first attempt, when the virgin ribs were inserted into the leading edge skin, the rib webs were actually warping from straight in order to fit the leading edge radius of the pre bent skin. This is ugly, and causes scratches and bumps on the leading edge of the skin. When compared to the fiberglass tip, I think the pre-bent skins have a different leading edge profile causing a poor fit. Here is a picture of the virgin rib fitting onto the skin. Notice how the tabs in front of the prepunched hole are holding the skin away.
I also rounded the tabs so they won't cause a dimple on the leading edge.
Everything fits much better. I am being careful to make the left and right wings the same, since this portion of the wing contributes to the flying qualities. Here is a picture of the reworked rib installed on the left leading edge. There is still a gap between the rib and the leading edge. I don't think it hurts anything, but I might throw some extra proseal in there when I do the tanks.
I also had an interference on one of the ribs to the spar rivets. This is the rib closest to the tank. Not hard to take care of. I am continuing on and looking forward to the Proseal Challenge.
Thank you
John S
Fuselage started
Old 05-29-2017, 10:37 PM
Default Tanks
I have been working on the fuel tanks. The Pro-seal is about to expire, so have been a mad man trying to get the tanks together.
Everything went per plans, but did some things that made it easier. Since I am doing both wings at the same time, the tooling and jigs get setup and taken down only once, so things go quick.
I made a template and verified the tank leading edge shape matched the outboard leading edge. The left wing I nailed perfectly, but the right I had to disassembly the ribs and tweak slightly. I also made the end ribs of the tank fit the curve of the skin as near perfect as possible to minimize the gap the Pro-seal has to fill in.
For the tank brackets I made a wood jig to hold the brackets and get the middle hole centered. Of course, all the brackets came from the factory exactly same length, except for two.Oh well.
The brackets are installed on the baffle and the line centered in the baffle holes. Then the remaining holes are drilled using the baffle as the drill guide. I found out that the baffle is not symmetrical; there is a top and bottom. In addition, the baffle flange orientation is mirrored on the right, but not shown explicitly on the plans, leading to additional confusion. You are warned.
After the brackets are drilled to the baffle they are installed on the tank, and the tank is installed on the wing for match drilling to the spar. There were several gotchas:
1) The baffle has a top and bottom, the prepunched holes are not symmetrical top to bottom.
2) The distance from the baffle to the spar is too close for clecos near the root. If I tried to use clecos to hold the tank skin to the baffle, the baffle and wing tank did not sit on the wing properly.
3) others have dimpled the baffle rivet holes; I don't see how this will not work on the RV9 since there is not enough clearance; I think the baffle rivet holes need to be countersunk per the plans.
After the brackets are match drilled to the spar, the riv-nuts are installed. I used a bolt and nut to drill the brackets for the rivets as in the pic. (The hole in the wood is for the nut to rest in.)
The rest went as per plans, nothing special. Prior to priming, I edge rolled the seams very slightly using my thumb technique. Not sure if this is needed, but I do not want any of the skins lifting off the spar and I could not find anyone on line who regretted doing this.
Lastly, I primed in prep for final assembly. The plans say only the bracket needs to be primed, but my minimum amount to mix easily is 50 ml. Not wanting to waste any, I primed the outside of the skins where they will rest on the spar and splice plate, the outside of the two end ribs, and the backside of the baffle. I am thinking the tanks may sweat when full of fuel, so I figure it wouldn't hurt to prime the outside that is exposed.
With all this work, I think I am ready for final assembly of the tanks. hope I have enough clecos ;-)
Thank you
John S
Fuselage started
Old 06-18-2017, 09:58 AM
Default Fuel Tanks - Part Duex, Is it a comedy or tragedy?
Tank assembly begins!
The bottom stiffeners were installed per the plans. I mixed up 1 gram of Proseal per linear inch, and this was just about right, taking into account losses from leaving stuff on the mixing plate, smeared on the ceiling, etc. Did I mention this stuff gets everywhere?
The next day, I mixed up another batch of Proseal per the instructions, and using the baggy technique, applied it to the ribs. I then cleco'd the ribs to the bottom skin using a cleco in every hole.
In the same session, I mixed a second batch and applied Proseal to the top of the ribs, inserted the tank into the frame and cleco'd the top of the skin to the ribs, again using a cleco in every hole. Then I smoothed the excess bleed out with the tip of the plastic knife, and let it set overnight. I added tape to keep the skins from spreading due to the Proseal's viscosity.
The next day, I came back and removed every cleco four at a time and used the #40 (-3) countersink to clean up the dimples. This removed the excess squeeze out and removed a sliver of aluminum to provide virgin material for the rivet to seal against.
I did not use "tank dies" but just the normal dimple dies. During riveting, the Proseal squeezed out and all that remained was what was needed to fill in the voids; Just my opinion.
The riveting went fine. I had to drill out a few clinchers, because the Proseal makes everything slippery. Also, if I didn't press the rivet down in the hole and squeeze out the excess, I would invariably get a rivet sitting proud. I used a hemostat to place the rivet in the hole filled with Proseal, pushing lightly to squeeze out the excess goop. Then I cleaned off the outside with a acetone-damped rag, cleaned the mushroom set, and riveted. I found using lower air pressure and feathering the trigger helped set the rivets without clinching. With 30 grams mixed, I was able to set 3 rows on the bottom, coat the shop heads and fillet the three ribs before the stuff started getting hard. It took me three nights over a week to get each skin on. With this fay sealing method, there was not a rush to set all the rivets in one session; I felt this made for much better results because I wasn't stressed trying to rivet everything before the Proseal set up.
The tanks skins and ribs are all riveted now. Looking back, I don't know why I was so apprehensive, but it was a learning experience. As a side note, I used MEK to clean the faying surfaces, but switched to acetone to remove the excess Proseal, to try and preserve my MEK for more important tasks; I can no longer buy MEK locally. (Time for a Vegas run, anybody up for Craps?)
Thank you
John S
Fuselage started
Old 06-18-2017, 11:06 PM
Default A different perspective........
I also have some concerns about the use of tank dimple dies, but in my opinion, by installing the ribs and then waiting to rivet, you just moved the thick build-up of sealant from between the rivet and skin, to between the skin and the rib.
The squeeze force of a cleco is much lower than what is exerted when setting a rivet.
The sealant is very viscous and doesn't easily squeeze out from between the rib and skin.
I am pretty sure that just installing clecos and then letting the sealant cure before riveting leaves a much thicker layer of sealant between the rib and the skin. Far less desirable than the result attained if riveted wet, in my opinion.
Scott McDaniels
Hubbard, Oregon
Old 06-25-2017, 07:11 PM
Default Fuel Tanks: Stop the Madness, I am Tired of Learning
Fuel tanks are done, Yippee Ki Ya!
This last week has been fun learning how to play with ProSeal. The baffles and support brackets went on without much trouble.
For those of you building a RV9, it is important to note that the baffle doesn't naturally want to sit properly. The top and bottom skins are designed to not sit perpendicular to the back of the baffle. So when the baffle is dropped in, it has to be forced to align with the internal ribs. Once the baffle was set down on the ribs, I pushed the baffle into alignment and pressed in a -4 rivet thru the baffle into the ribs. This kept the baffle lined up while I inserted the gazillion silver clecos for the top and bottom row of -3 rivets, and clecos for the rest of -4 rivets for the baffle to ribs, without the brackets.
For the -3 clecos. I pushed in a -3 rivet every 10th hole to line up the skin and baffle before clecoing. Once all the clecos were inserted, I gently squeezed between each -3 rivet location with a Vise Grip welding pliers to squeeze out any excess Proseal.
I started riveting the -3's at the middle of the tank. I found I had to take the countersink (with a countersink stop) and touch up each hole before inserting the rivet; otherwise the heads were not always flush to the skin.
For the baffle to rib to bracket rivets, the pop rivets went in smoothly. I made sure I set the -3 and -4 rivets in one seating so the Proseal didn't have a chance to harden.
The sender, pickup and drain went in as per plans.
I am now in the waiting period when I am ignorant and happy, thinking the tanks are done and won't leak. Here is my leak check setup using the manometer method. I am expecting I can blow in the tubes enough to pressurize them to 27" of water. I am holding my breath hoping they won't leak.
Thank you
John S
Fuselage started
Old 06-30-2017, 07:14 PM
Default Fuel Tanks- Didnt Hold My Breath Long Enough
Last report, I was holding my breath the fuel tanks would not leak.
Like all good learning experiences, my tanks leaked; both of them, mainly from the rear seam.
The one tank leaked from the seam near the fuel sender and access hole. This was easy enough to fix by removing the access panel and adding more goop.
The tank in the picture leaked from the top seam near the middle, in 2 places. Ugh.
There were many options I found on-line to fix this:
1) use Loctite adhesive designed for just such a repair.
2) ignore it and hope it goes away.
3) cut a hole in the baffle, add more sealant and then use a new access plate to cover over hole.
4) use the really thin Proseal that is brushable, pour it in the tank and slosh it along the seam.
5) make a funky applicator with a syringe and tubing; using a USB camera, and add some more Proseal to the seam thru the filler neck or the sender access panel.
Of course, being the expert builder that I am, I did none of the above.
I decided to use option 6), which is not listed above. If that didnt work, use option 3.
Option 6) was to drill out the baffle rivets in the offending area, wrap a towel around the vacuum cleaner nozzle and tape it to the fuel filler spout. With the manometer hooked up, turn on the suction and leave the fuel sender screws out to avoid over pressurizing the tank (wouldn't this be under pressurizing?). Add some Proseal to the seam, and gently open the seam up by gently flexing the tank skin. To my surprise, the sealant sucked itself into the gap. I used a heat gun to gently heat the tank skin to help the Proseal flow into the cracks. The whole time the tank was under 27" of vacuum.
After resetting the rivets, I let the tank sit for a day. I started the pressure test tonight, and the leak check using soap bubbles showed no leakage. Normally I would say done, but I plan to let it sit over night just to make sure.
Thank you
John S
Fuselage started
Old 06-30-2017, 07:26 PM
Dbro172's Avatar
Dbro172 Dbro172 is offline
Nice work. If you really want a good test, fill it with 100LL. Fuel will find leaks that air and bubbles wont.
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
www.mykitlog.com/dbro172/
1968 Mooney M20C - Sold
1956 C-182 - Sold
Old 07-29-2017, 12:51 PM
Default One line, one month
I was trying to get at least one page of instructions done per month.
Got the fuel tanks done in two months and that was about two pages of instructions.
Than I ran into the next step:" Deburr, Dimple (prime) main skins"
Really simple sentence, but took me a month.:-)
But this is summer and I am distracted. Here is my typical view during my Saturday morning runs.
Hard to get into build during the beautiful summer days. But I am making progress, skins are done and am working on countersinking the spar to accept the skins.
I never installed the flush rivets for the ribs that go under the tank skins, so am doing that now. I wish I would have done this when the ribs were riveted to the spars, and before the skins were matched drilled. So now I have to c-sink the ribs holes under the tank to flush, and the ones for the skin to 0.007" deeper per the plans. I will probably squeeze these rivets right after I dab primer on all the spar c-sink holes; this primer may not be required, but I am going to do it anyway, at least for the main spar.
Working on stall warning now. And hope to get the top main skins on before the end of August; although the beach looks mighty inviting.......
Thank you
John S
Fuselage started
