Old 06-18-2017, 04:51 PM
petehowell's Avatar
Default 1800 Hr Borescope Pics
On the way home from the dad's day fly-in @ KTOB Andi and I took Niner-pop-hotel over 1800 hrs. So I dropped the oil, checked the filter, checked compression, and scoped the valves.
Filter was clean, compressions were above 77/80 on all cylinders, and the valves looked pretty good - plugs were clean, too. #4 cylinder clearly got into the Spotted Cow........
O-320/Carb/EI/Mogas/Lots of LOP.
#1==========================
#3=========================
#2====================
#4============================
Pete
Amateur Plane - RV-9A N789PH - 1900+ Hrs
Amateur Radio - KD0CVN
Doggies Delivered - 20 and Counting
St. Paul, MN
Old 06-18-2017, 06:59 PM
walldan's Avatar
walldan walldan is offline
Default No pictures?
Pictures are not showing.
DW
President of EAA Chapter 992
Hatz Biplane under construction
Future Builder RV-6/7/9/14 <Green light to order... must decide!
Retired Volunteer Firefighter & Active EMT
Old 06-18-2017, 08:00 PM
sprucemoose's Avatar
sprucemoose sprucemoose is offline
#4 cylinder clearly got into the Spotted Cow.........
False. Spotted Cow is not permitted in MN.
Jeff Point
RV-6, RLU-1 built & flying
Tech Counselor, Flight Advisor & President, EAA Chapter 18
Milwaukee
Old 06-18-2017, 08:35 PM
BillL BillL is offline
Ditto . . .
Edit: suddenly they appeared - maybe slow connection. ??
#4 and #1 look like twins - sure they are the right pictures? Look at the seat ring chips, and pattern on the valve.
Bill
Op Lims in hand 12-7-17
1st Flight 1-27-18
2017 Dues Paid
Old 06-18-2017, 09:51 PM
petehowell's Avatar
Default Good catch
Bill - good catch - I replaced one of the photos - still not sure if they are all in the right place. They all looked fine in the end. - Big sigh of relief!
Ditto . . .
Pete
St. Paul, MN
Old 06-18-2017, 09:59 PM
DHeal DHeal is offline
Great photos -- what kind of boroscope did you use?
EAA #23982 - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 600+ hours (as of Feb 2018)!
VAF donation through June 2018.
Old 06-19-2017, 06:57 AM
petehowell's Avatar
We make weekly "Smoky and the Bandit" runs to Boyceville. Buford T. has not caught on quite yet........
Pete
St. Paul, MN
Old 06-19-2017, 07:39 AM
Carl Froehlich's Avatar
Pete - thanks for posting the results. Great training material.
Old 06-19-2017, 09:23 AM
1001001's Avatar
1001001 1001001 is offline
I second the request on borescope type!
Old 06-19-2017, 10:01 AM
petehowell's Avatar
I forgot my cheapie micro brew scope at home, so these are from the ablescope that many people here have. Hooked it up to the smartphone and snapped away.
Pete
St. Paul, MN
