Old 06-06-2017, 11:48 PM
control control is offline
Make sure to get the one with one end angled:
http://www.cleavelandtool.com/Tungst.../#.WTeS7GddBaQ
The above one and this one below (for the 1% that the above cannot handle) are the only two ones I use:
http://www.cleavelandtool.com/Footed.../#.WTeTdmddBaQ
RV-14 kit #140138
working on FW forward and finish kit
wings, tail kit and fuselage basically done
Http://magnusrv.blogspot.se
Old 06-07-2017, 10:05 AM
FL-flyer's Avatar
FL-flyer FL-flyer is offline
Thanks everyone, I will order the 4" bar!
I also found a smaller 2" x 1.5" bar. Does anyone think this would be helpful?
http://www.tungstenbuckingbars.com/d...ons/ETBB03.pdf
Casey M
Sarasota, FL
EAA 180
Starting on empennage section - August 2016
Old 06-07-2017, 03:23 PM
vfrazier's Avatar
vfrazier vfrazier is offline
Blake also has an assortment of U.S. made bars.
http://www.flyboyaccessories.com/Han...ilders-s/5.htm
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold
Old 06-18-2017, 05:53 AM
FL-flyer's Avatar
I received my 4" x 1"x 0.625 bucking bar today and I was blown away what a difference this makes. Not only is it easier (and a lot more comfortable) to use but the quality of the shop heads is also improved. You get a satisfying feel of the rivet tail collapsing and forming the shop head.. I want to send my steel bars to the smelter now. Thanks everyone for the recommendation!
The 4" x 1"x 0.625 bar (referred to as the snickers bar) looks like it would work for most situations, but for $70 I just ordered another bar that is 2" x 1.5" x 0.625" (referred to at the brownie bar). I think the brownie bar will be better suited to get into rib flanges. Anyone else have one of these and if so, do you find it useful?
Casey M
Sarasota, FL
EAA 180
Old 06-18-2017, 07:18 AM
agirard7a's Avatar
agirard7a agirard7a is offline
Default Angled face.
Angled face a must have! It allows bucking in restricted spaces.
This is the one I would recommend.
I have one like it. It use to be called the "ultimate bucking bar"
http://www.flyboyaccessories.com/product-p/3204.htm
Al Girard, Newport, RI
N339AG
RV-9
Old 06-18-2017, 03:31 PM
maniago's Avatar
maniago maniago is offline
I've used this one for 99.99% of my bucking. Then I discovered that I can make any custom shape needed out of steel plate and c-clamp to the bucking bar for the really odd place. Now its my 100% bar. No need for any other bar.
http://www.tungstenbuckingbars.com/d...ons/ETBB13.pdf
Mani
Bushby Mustang II (Folding Wings) "Wiring stage. Yea!" IO-360B1E,RSA,C2YR-BF/F7666-2,Superior sump,James; 2xHXr,Mini-x,EIS,480,327,240,SL30,Echo; SteamAlt,AS,VSI
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
Dec2017
