Old 06-13-2017, 10:45 AM
Auburntsts's Avatar
Originally Posted by jwilbur View Post
I've got Crow harnesses. As Todd says the lengths are different between front and back, but the rear belts also come together and have a single attach point at the anchor - same as the front belts.
Joe, the stock harnesses all have a single attach point but the fronts merge into a single strap before the fitting while the rears don't.
Todd Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 06-13-2017, 10:50 AM
jwilbur jwilbur is offline
Originally Posted by Auburntsts View Post
Joe, the stock harnesses all have a single attach point but the fronts merge into a single strap before the anchor while the rears don't.
I understand. With the Crow harnesses both front and back merge into a single strap before the anchor. Here's a link to their web site showing what the 5 point rear straps look like.
http://www.parts123.com/parts123/dyn...71a&ukey=AAAMI
-Joe Wilbur (N520LW)
Phase II - 11/2017
First flight - 8/2017
Pink slip - 7/2017
RV-10 Build Log
Old 06-14-2017, 08:06 AM
NovaBandit's Avatar
NovaBandit NovaBandit is offline
Yup. That's how mine are. As far as I know, all 4 harnesses are identical. Lengths and all. The anchor brackets are different, but come in a separate bag, and you just thread the webbing thru after the brackets are bolted in.
Again, this is for the Crow harness.
Ed Kranz
RV-10 N829EC - Flying
First Flight: 8/29/15
KSGS - Fleming Field, South Saint Paul, Minnesota
YouTube.com/GoodPlaneLiving
-- Build Timelapse and Travel Videos . . GoodPlaneLiving.com -- Build and Travel Blog
