Old 06-13-2017, 03:33 PM
Greenley's Avatar
Greenley Greenley is offline
Default Manifold Pressure Manifold Needed
The 6-cyl pmags coming out each need a manifold pressure input, and that combined with my G3X manifold pressure sensor has me thinking of some kind of firewall mounted manifold that I could screw in the G3X sensor which has 1/8" NPT threads, and two nipple fittings to put on the 1/8" ID hoses from the pmags, and of course the input from the engine.
Any ideas of something light and compact I could put on the firewall to accommodate this?
Bill Greenley
RV-10 standard in progress, working on the fuselage
looking forward to making airplane noises in SW Michigan
Old 06-13-2017, 03:57 PM
Auburntsts's Avatar
How about the VA-168 sender mount that comes in the FWF Kit?
Todd Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 06-13-2017, 04:14 PM
Greenley's Avatar
I looked at that for one gauge, but I will need three outputs for one input.
Bill Greenley
Old 06-13-2017, 04:40 PM
Auburntsts's Avatar
Oh, yeah 2 PMAGs. Well maybe you could Tee the MP input at one of the PMAGS or the sender mount:
Todd Stovall
PP ASEL-IA
WAR EAGLE!
Old 06-13-2017, 05:06 PM
Mark Albery's Avatar
Mark Albery Mark Albery is offline
I used a manifold fitting from summit racing to tee MP connections to the PMag and cockpit gauge:
https://www.summitracing.com/parts/zex-82104/overview/
Old 06-13-2017, 05:40 PM
Ironflight's Avatar
VAF Moderator / Line Boy
The QD pitot/static fittings that you buy from Stein come in a variety of configurations (including a "Y"), and fit the manifold pressure tubing supplied with the P-Mags perfectly. I bring the lines from the two P-mags together wherever it is convenient for the "Y", and tie that to the engine mount, then run a single line from there to the VA-168, which also mounts the EFIS MAP sensor - works great on our three airplanes set up that way.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 06-13-2017, 05:44 PM
Greenley's Avatar
I found this and thinking I could fasten it to the firewall somehow and use this for a manifold.
https://smile.amazon.com/gp/product/...A1THAZDOWP300U
Bill Greenley
Old 06-13-2017, 06:47 PM
WE make an inline tee with 2 branches for the P Mags, and the end to connect to the pressure manifold. Crimped onto a teflon hose, with 2 short static tubes for the P mags.
You are actually getting the 6 cyl. P Mags?
Tom
Tom Swearengen, TS Flightlines LLC
Ridgeland, SC
www.tsflightlines.com
Old 06-13-2017, 07:51 PM
Greenley's Avatar
I forget, Tom can do anything. Great solution. No I do not have the 6 cyl yet, but I am setting up for them and regular mags with a shower of sparks.
Bill Greenley
