Old 06-12-2017, 11:29 AM
AviatorJ AviatorJ is offline
Default Door latch resistance
I have a few more days until I'm complete with the doors and cabin top. A couple finishing touches, some final fill and that's all that's left! Pretty excited about it really.
Anyhow I went with the McMaster Seal and spent a lot of time getting the 1/4 gap between the inside shell and the flange. However when latching it, the door seems overly hard to close.
Is this normal, I've only had the seal on with the door shut for 3 days...
Justin
RV-10 Quickbuild 'Cowling!!, Avionics and Interior'
http://operationrv10.blogspot.com/
Donated for 2018
Old 06-12-2017, 12:31 PM
rleffler's Avatar
rleffler rleffler is offline
It's normal for the seal to make the door very tight for awhile. Usually it is the upper seal that binds. But if it's too overly hard to close, I would look to ensure that the gaps are not too small.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 06-12-2017, 01:46 PM
TimO TimO is offline
Lube the pins with some lithium grease and see how that goes.
Tim Olson - CFI
RV-10 N104CD - Flying 2/2006 - 1300+ hours http://www.MyRV10.com
RV-14 N14YT - Flying 6/2016 - 175+ hours http://www.MyRV14.com
RV-10/14 Transition Training: http://www.RVCFI.com
Old 06-12-2017, 02:13 PM
N427EF N427EF is offline
Default Same here
Especially where they enter the door frame.
You want the doors tight!
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 400 plus hours
Over 2500 Gallons of E10 mogas burned
Don't believe everything you know.
Old 06-12-2017, 02:23 PM
Did some troubleshooting, basically pulled the seal off only the top.. then closed the doors which were substantial 'easier'. Then I started putting the seal back on little by little to fight when it started getting tough to latch. On one door it was the top forward curve. On the other door it was the back top curve. I sanded about 1/16" off these areas and put the seal back on. Door closes much 'easier'. It's a one handed close, not sure if it should be a easier than that.
I'll give the seal a bit more crush time and then if it's still rough I'll go for some grease. It's a pretty tight shut.
Justin
Donated for 2018
Old 06-12-2017, 08:00 PM
rleffler's Avatar
I'm glad things worked out. That's why they're called experimental, it's just one experiment after another.
Bob Leffler
Old 06-13-2017, 06:17 AM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
My seal crushes less than 50% of it's diameter. It took around 50-100 hours for everything to loosen up, but I can turn my handles with a couple of fingers at this point.
Bill Peyton
RV-10 - 780 Hrs
First Flight Oct 2012
WA0SYV
Aviation Partners, LLC
Old 06-13-2017, 09:00 AM
Strasnuts Strasnuts is offline
Default one more check
One thing to check if you have the PlaneAround latch is to make sure the pins are not pushing the cam shoulder or shaft down against the block. When I built the first latch I noticed this could could happen. I relieved the block a little. My suggestion (if you have the planearound latch) is to take the center block out and try closing the door to see if it is easier. There should be very little to no resistance with the planearound latch. If it is easier try sanding the middle cam block down on the bottom so it sits lower or grinding the top of the block circular to match the cam shoulder and try again. Usually it is a couple areas of the seal being too tight.
A&P RV-10 Flying 850 hours
SuperSTOL Flying 100 hours
