Old 03-22-2017, 04:21 PM
Originally Posted by magiccarpet View Post
I also wonder what Synergy does in their serial production.
All production since the change was published has been without the cooling shroud.
Scott McDaniels
Hubbard, Oregon
Old 06-10-2017, 08:28 PM
tomkk's Avatar
tomkk tomkk is offline
It sounds like there's no particular advantage to leaving the cooling shroud off? That is, if it's already installed, is there any reason to remove it?
Tom
Port Orange, Fl
RV-12 N121TK ELSA #120845
First flight 06/10/2015
Old 06-11-2017, 01:07 AM
No
If there was, a notification would have been published recommending that they be removed.
More recent testing showed that the cyl. cooling was about the same with or without the shroud, so it was deleted to reduce the kit cost and reduce the chance of a builder induced problem during the engine disassembly and reassembly that was required to install it.
Scott McDaniels
Hubbard, Oregon
Old 08-13-2017, 12:26 PM
waterboy2110 waterboy2110 is offline
There is definitely an uneven cooling with this plenum design. The design itself is questionable in that it places the #2 cylinder in a corner away from the airflow - it is clear that the #2 cylinder would be starved for cooling until enough ram are were available to charge the plenum with a high enough pressure to force an even airflow.
As for disassembly of the engine - most know that at one point Rotax insisted that you not change your oil without the service class. Not sure if that's still true but I think it's safe to assume a fair number of folks have installed the engine without any Rotax training. It's not a difficult job - but I'm sure Rotax has concerns.
http://jimsrv.blogspot.com
PP - ASEL
Instrument Rating
A&P / Rotax iRMT 9 Series Maintenance
RV12 Flying.
