Old 05-23-2017, 09:19 AM
bkervaski's Avatar
Default IO-390 Engine Stand
All,
I took advantage of the Sun-N-Fun special and ordered an IO-390 with the discount. It's going to arrive 4-5 months before I'm ready for it. Of course, I want to unpack and inspect it when it arrives .. is there a good engine stand recommended?
Thanks for any advice!
Reserved: N196
Progress: All Kits Done
Old 05-23-2017, 10:00 AM
TCONROY's Avatar
TCONROY TCONROY is offline
If it is going to sit for several months before you need it, I would suggest leaving it bolted to the crate/pallet that it is shipped on and leaving the vacuum packing untouched. This will keep it preserved until you are ready for it.
________
Trevor Conroy CFII, MEI
Airbus Pilot
N781TD
First Flight - April 12, 2015
Construction Log
Old 05-23-2017, 08:26 PM
n982sx n982sx is offline
Just so you know what to expect. I assume it will come like mine did. It is not bolted to the pallet. It is vacuum sealed in a bag but is encased in foam inside the corrugated box.
You just take the top off the box and lift it out with a shop crane. No bolts.
If you want to examine it, to lift it you will have to puncture the sealed bag. You should just leave it sealed until closer to when you need it.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 06-05-2017, 05:33 PM
bkervaski's Avatar
Thanks Bob.
It's coming in Aug with my QB fuse .. won't get it as soon as I thought.
Reserved: N196
