Walt
According to the FAA website if your system does not meet the GPS perfomance parameters below then you will no longer be able to receive ADS-B services after 2016.
So for those of you on the fence about equipping with a position source meeting these minimum performance requirements (which our experimental EFIS GPS's do not) this may be some "incentive" to rethink that (bottom line is your will lose traffic services for those broadcasting with a non-certifed GPS position sources)
Quote from the FAA site:
"However, beginning on January 4, 2016, the following criteria must also be satisfied in order to receive ADS-B IN services: Broadcast ADS-B with NACp>4, NACv>0, SDA>0, SIL>0, and NIC>4."
I personally plan on asking the FAA why the restriction and how that is going to improve safety at every opportunity I have while attending Oshkosh, I suggest everyone do the same, let them know how you feel !
