I have two cylinders(#2,#3) with low cht readings. 70 to 100 My EGT's are all real close on all the cylinders (1300). Oil pressure and oil temperature is normal for the cold weather. Engine runs great and sounds fine. I am thinking it has to be bad probes. I have MGL K type probes that screw into the cylinder. They are fairly inexpensive. I wonder if getter a better quality probe would help and can I get any K type probe that screws in or do I have to stick with MGL.
