Ouick Oil Change Question
sailvi767
Does anyone know with the safe air quick change valve what diameter tubing you need to slip over the fitting for draining the oil? I am guessing about 3/8 inch inside diameter but wanted to pick some tubing up on the way out to the airport.
Thanks!
George
use 1/2 "
may have to neck down the top a bit with a couple wraps of safety wire.
The larger diameter flows better.
