You can modify the cap tabs by putting a larger radius where they work against the stainless plate with a scotchbrite wheel. I can open mine easily and they seal perfectly. I haven't touched the caps with a tool in over ten years.
My finger........ Properly maintained, you can open them with your finger.
i got new o -rings and the instructions on how to check the tightness of the o-ring suprised me on how loose they were, the important part seems to be the lubrication of the o-ring. what do people use for this? what is the true function of "fuel lube that i have seen in catalogs?
I keep popcicle sticks around.
they are perfect to open the gas cap.
And
Easy Turn on the O ring
I whittled the (other) end of my fuel dipstick down to a point, dead easy and works a treat
