Garmin Pilot W+B
bkervaski
Hellloooooooo!
Testing
Is anyone using the Garmin Pilot W+B app? If so, how did you determine the numbers for the envelope?
Good question, I have been playing with the W&B on Garmin Pilot and have not been able to get it running??
Dick
I use it and had no issues, but I don't have my ipad here at the office to drill into why you're having problems. I just RTFM and followed the instructions.
I use it with no issues. To keep it simple I set up my envelope in the Normal Category defined by these 4 points:
Empty weight, most forward CG
GW, most forward CG
GW, most aft CG
Empty weight, most aft CG
I also set my Ramp weight at 8 pounds higher than GW so I could account for startup and taxi fuel burn and still depart at GW.
