Dynon HDX rpm band
Joe Parish
Does anyone know if the yellow section in the RPM band on the HDX can be removed? It is a small band I assume that it is for some set ups with a RPM restriction on the engine prop combo. Just curious if it can be reprogrammed? Thanks Joe
HDX is customizable
Yes, all the colored bands on the engine transducers and other meters are user controlled on HDX. I adjusted mine about a month ago. You can change the numbers where colors begin and end. You can add a 4th color. You can delete colors. I'm not at the HDX right now, but just go into setup and poke around. You'll find it.
