Do new experimental airplanes require all inspections required for normal aircraft prior to receiving their air worthiness certificate?
In other words, do I need a transponder check and elt inspection prior to receiving my airworthiness inspection?
Thanks Mel. Who does the condition inspection? i assume it cannot be me if do not hold a repairmans certificate.
Correct, for the airworthiness inspection you'll either need a DAR to come to you, or have the local FSDO send a guy to you. Both have pros and cons. I would recommend the DAR route, specifically Mel because he will do an actual INSPECTION of the airplane with hands and eyeballs rather than just a paper chase. If there is something wrong, he'll see it and bring it to your attention, which is what you really want to happen.
For the initial condition inspection, the builder does it, no repairmans certificate needed for that first one.
Hey Mel...what's your fee for doing an inspection in Hawaii? Airfare and three nights in a nice hotel on the beach??
Both myself and my DAR agreed with Mel: transponder check before flight (I'm in mode C required airspace) but after inspection was okay. But the DAR said he would check with the FSDO "just to be sure", and those guys said I needed the transponder checked first! Rather than argue with them, I just had it done. As others have noted, the builder must sign off the condition inspection prior to the AW inspection, including an ELT check.
I think the local FSDO option is probably hit-or-miss regarding an actual inspection. I had a FSDO guy come and he spent about 4 hours poking with a flashlight into every part of the airplane. I had a page worth of things I needed to fix (all minor stuff, but still). It was invasive. But he did leave me with some confidence that the airplane was in good shape. I was actually relieved that it wasn't just a paperwork inspection.
