Old 02-01-2018, 11:33 AM
Auburntsts's Avatar
Originally Posted by David Paule View Post
Let's not forget that even if the LSA category gross weight limit went up, that would not affect any existing aircraft. RV-12, for example, has a gross weight established by structural and performance considerations, which would not change. Only new clean-sheet designs (and some heritage non-LSA airplanes, e.g., a C150) would get the higher gross weight.
Dave
Maybe. I'm thinking that the CarbonCub SS LSA with it's 180hp might benefit from a GW increase since it already has E-AB and Far 23 brothers and sisters.
Todd Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 02-01-2018, 11:50 AM
Greg Arehart's Avatar
Greg Arehart Greg Arehart is offline
Is no night flying part of LSA? I thought if you had a PP ticket and "downgraded" to LSA, you could still fly at night, or if you had a sport pilot ticket you could do some training and fly at night.
Greg Arehart
RV-9B (Big tires) Tipup @AJZ or CYSQ
N 7965A
Old 02-01-2018, 11:57 AM
N941WR's Avatar
N941WR N941WR is offline
Sorry, thinking about the pilot, not the plane.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 02-01-2018, 12:02 PM
Mel's Avatar
Mel Mel is offline
You should also remove "No IFR". Again, that's a pilot rule, not aircraft.
A&P/EAA Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 02-01-2018, 01:44 PM
N941WR's Avatar
OK, removed
Bill R.
SC86 - Easley, SC
Old 02-01-2018, 04:21 PM
RV12JT RV12JT is offline
Dave
How would that change a plane like the Sling2? Which I believe when experimental built or is sold outside the US, can have a gross weight of 1540 lbs. no structural difference, just paper. Do you think there would be a way to up the weight?
Old 02-01-2018, 05:06 PM
rgmwa rgmwa is offline
The Sling was designed to meet the EASA CS-VLA (Very Light Aeroplanes) Specification which allows a MAUW of 700 kg (1540 lb).
rgmwa
120346
Old 02-01-2018, 05:56 PM
vlittle's Avatar
vlittle vlittle is offline
Let's say that the FAA changes the gross weight/stall speed restriction to a kinetic energy restriction.
A 1320 lb. LSA with a stall speed of 45 knots has the same kinetic energy at stall as an 1850 lb. plane with a stall speed of 39 knots, using e = 1/2 mV^2.
Now, that would allow a lot of flexibility in design... but the low stall speeds may have troublesome crosswind issues.
V
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 under construction
Old 02-02-2018, 08:46 AM
Snowflake's Avatar
Don't forget about the guys (somewhere in Florida I think?), who were selling RV-9's as Light Sport by claiming to have optimized the build for extreme weight reduction during construction... Power limited to 50% throttle after takeoff or some such silliness.
Rob Prior
Old 02-02-2018, 09:01 AM
Mel's Avatar
Mel Mel is offline
Dreaming is nice, and of course anything is possible, but I wouldn't hold my breath on this one.
North Texas (8TA5)
FRIEND of the RV-1
Eagle's Nest Mentor
