Old 08-15-2007, 12:03 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Default Knots to You....
I love it AJ...."When I have to run from a bad date, I get in my 200 mph+ airplane and leave the state!"
Now I know how all you speed demons like to use mph goes the numbers are bigger, but hey, if that's all you want, why not post in kph? I had a professor back in college (Senior Design, Aeronautical Engineering) that would not even accept a paper or report if all the units weren't in Knots...."That's the units we use in aviation kids, like it or 'knot' !"
Hmm....I need to keep that camera charged and along - got some long trips coming up, and maybe I can catch a wind....
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 08-15-2007, 12:08 PM
grantcarruthers's Avatar
grantcarruthers grantcarruthers is offline
Yah but you have to stay 2000 agl over national park airspace so you still can't get a neg MSL indication. I've considered it before and don't think there is anywhere to get a neg MSL???
Am I right about the 2000agl even??
RV-8, Both wings with top skins on
-4 bought flying
Old 08-15-2007, 12:57 PM
Tandem46's Avatar
Tandem46 Tandem46 is offline
Yep:
Pilots are requested to maintain a minimum altitude of 2,000 feet above the surface of the following: National Parks, Monuments, Seashores, Lakeshores, Recreation Areas and Scenic Riverways administered by the National Park Service, National Wildlife Refuges, Big Game Refuges, Game Ranges and Wildlife Ranges administered by the U.S. Fish and Wildlife Service, and Wilderness and Primitive areas administered by the U.S. Forest Service.
NOTE-
FAA Advisory Circular AC 91-36, Visual Flight Rules (VFR) Flight Near Noise-Sensitive Areas, defines the surface of a national park area (including parks, forests, primitive areas, wilderness areas, recreational areas, national seashores, national monuments, national lakeshores, and national wildlife refuge and range areas) as: the highest terrain within 2,000 feet laterally of the route of flight, or the upper-most rim of a canyon or valley.
The above is clearly depicted on all US sectionals.
RV-7 Flying since 2004
1,000 hrs+
Old 08-15-2007, 01:33 PM
n700jl n700jl is offline
Default 200kt club
Well here is mine. photo link yes it is in a bit of a dive but it is still 200kts.
Jon Hubbell
RV-6 Flying IO-320X tip up 500+hrs G3X 2004 Oshkosh Outstanding workmanship award, 2004 Sun N Fun Best Workmanship
RV-10 Flying IO-540-C4B5X 300+hrs G3X 2011 Bronze Lindy Award Winner
"Negative Ghostrider the pattern is full"
Old 08-15-2007, 01:35 PM
Default 200kt club
This has been fun reading everyones stories. These are amazing airplanes keep building!
Jon Hubbell
Old 08-15-2007, 01:38 PM
hecilopter's Avatar
hecilopter hecilopter is offline
Default Neg MSL
If you were sitting at sea level and the temp was below 59 degrees f and/or the barometric pressure was > 29.92, you would get negative Density Altitude.
In the same situation, if the barometric pressure was > 29.92, you would get a negative Pressure Altitude.
You would physically have to be below sea level to get a negative MSL with the altimeter set correctly.
Is my thinking flawed?
Rusty "Rooster" Williams - FFI Wingman
N357RV RV-7A Tip Up (flying and Painted!) - 1130+ hrs.
Superior XP-360, carbureted, Hartzell 74" Blended Airfoil Prop
Grand Prairie, TX
KGPM
Old 08-15-2007, 02:16 PM
kentb's Avatar
kentb kentb is offline
Default Furnace Creek Airport (L06)
Elevation: -210 ft
A low pass should get you -180 or so.
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
Old 08-15-2007, 02:18 PM
dan's Avatar
dan dan is offline
I see what's happening here. Nobody could beat 252 knots (290 mph) groundspeed, so the conversation shifted to density altitude. What a copout...
C'mon, Kahuna -- I know you've seen faster than 252 knots GS!
And Rocket guys, I know you don't fly your airplanes more than about twice a year because of how expensive they are to operate, but c'mon, I know you can beat 252 knots GS!
Muuaahahahaha.
Dan Checkoway RV-7
Old 08-15-2007, 07:17 PM
EMPTY EMPTY is offline
Default Join the 200KTS Club
Just a little hopp from PHX to 5T6 (Santa Teresa, NM). Felt like we were "Coming Down The Shute" @ Reno Air Races. The Pic was from the hotel room when Lovey was reviewing our flight. I told her, "Take a photo, that ones a keeper!" Don't know if we can duplicate it for LOE '07 but, we're gonna try. 282.6 KTS
Michael Taylor (EMPTY)
N164MT
RV-6 L-0360, Hartzell C/S
Old 08-15-2007, 08:00 PM
aadamson's Avatar
aadamson aadamson is offline
Ah, now see, you should have stipulated more stringent requirements. Anyone who's got a High altitude to low altitude descent can come up with some pretty spectacular speeds (staying away from VNE obviously). But I think this needs to be refined....
How about 200kts of GS or better in *cruise level*. I'm sure I could dig up a few of those, but I suspect that would be cheating... On a flight from ATL to ORL at 15000, with an indicated of 145, a TAS of 190, it doesn't take much of a tailwind to get ahead of 200kts in GS in level flight...
Anyway, I think the rules need to be defined as above.... 200kts or better in a descent just simply isn't fair...
Alan Adamson
Atlanta, GA
Lancair Legacy FG-6 - N60AL (fixed gear, carbon fiber, IO-550)
Lancair Legacy Builders Forum
Beta Test Blog of Vertical Power install
