Old 10-17-2008, 11:29 PM
dhall_polo's Avatar
dhall_polo dhall_polo is offline
Default tip-up canopy seal
Anybody care to recommend some weather seal for the canopy?
(1) the seal that runs along the longeron...
(2) the seal across the front on the subpanel bulkhead
(3) seal around the canopy frame*
* someone offered to me that I should not seal around the canopy frame since that's intended to be where air escapes the cockpit for good ventilation. I have a sikaflex installation, so there is more of a gap between the forward canopy and the frame than there would be for a stock screw-type installation.
Old 10-18-2008, 06:43 AM
Brantel's Avatar
Brantel Brantel is offline
Planning to use the stock Van's seal for the front deck.
I used this seal for the sides (www.mcmaster.com part #1120A111)
And I put a targa on for the rollbar area so no seal there.
Brantel (Brian Chesteen),
Check out my RV-10 builder's BLOG
RV-10, #41942, N?????, Working on Emp/Tail Cone
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 06-23-2012, 03:15 PM
TCONROY's Avatar
TCONROY TCONROY is offline
I'm researching the seals people are using for their tip-up and am curious what a "targa" is. Excuse my ignorance.
________
Trevor Conroy CFII, MEI
Airbus Pilot
N781TD
First Flight - April 12, 2015
Construction Log
Old 06-23-2012, 06:07 PM
jjconstant's Avatar
jjconstant jjconstant is offline
Default targa strip
A targa strip usually refers to a 3 or 4 inch wide strip on tip up canopies that is attached to the trailing edge of the tip up. When the canopy is closed the targa overlaps the roll bar so there is no open seam between the canopy and roll bar/ rear window.
All Best
Jeremy Constant
RV7A "Stella Luna" ECI IO-360 WW200RV Pmags 360hrs
VAF 2019 paid plus some for those who can't
Old 06-23-2012, 09:47 PM
TCONROY's Avatar
Thanks for the info! I've seen those before but didn't realize there was a name for the mod.
________
Airbus Pilot
N781TD
Construction Log
Old 06-24-2012, 10:15 AM
Pmerems's Avatar
Pmerems Pmerems is offline
Default Seals
I have been using the following seals for #1 and #2
http://www.mcmaster.com/#bulb-seals/=i4975f
Style 5 and 9
I used the thinner seal for #1 and #2 and a thicker seal for #1 forward of the instrument panel.
I used 3M edge guard along the roll bar for my #3 seal. I originally used the UHMW tape (similar to Van's). It will yellow with exposure to sun and the adhesive is a PTA to remove. I replaced it with the 3M product. Working great. If you don't put some sort of material down between the roll bar and the canopy due to vibration the plexi will abrade the paint and plexi will also scuff.
FYI I did purchase the seals mentioned in the previous posts but found them too thick and would let the canopy seat properly. I have a 1/8" gap between the canopy frame and canopy rail.
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero-HANGAR BANNERS
www.experimentalaero.com
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
Old 06-26-2012, 09:17 AM
jpharrell jpharrell is offline
Default Part Numbers?
Paul,
Could you be more specific about which parts you used? When I go to the link you posted there are lots of options and it's not clear which ones you are referring to. I'm at the stage right now where I am finishing up my tip-up canopy so this is timely for me.
John Harrell
RV-7A Tip-up, Aero Sport Power IO-360, Dual PMags, AFP FI, Catto 3-blade, Dual Dynon Skyviews
Flying since August 2014
Mission Viejo, CA
http://www.johnsrv7a.wordpress.com
Old 06-26-2012, 10:21 PM
Pmerems's Avatar
Default McMaster-Carr part numbers
I purchased several seals a few years ago.
Here are the McMaster-Carr part numbers:
93085K11
93085K125
93085K67
These have self adhesive and are easy to install. Measure your gaps and determine if these will work. Keep in mind that during flight the canopy will lift and the seals may not seal completely. However you don't want a seal that when compressed doesn't allow the canopy to close properly. This is very important when installing a canopy front skin seal.
Additionally I purchased the Self-Gripping Vinyl Edge Trim with Metal Core (8451A22) to wrap the edge of the glare shield.
Old 12-02-2012, 09:44 PM
Flying Scotsman Flying Scotsman is offline
Re: the seal on the front subpanel bulkhead...I'm a little confused about where this goes. On top of the flange on the bulkhead (flange faces up)? Do I have that right?
Getting ready to order some stuff from McMaster (really liked the bulb seal along the sides)...
Steve
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
Old 12-17-2018, 11:55 PM
cook_ts cook_ts is offline
Default McMasterCarr
If you can find 'it' in Aircraft Spruce or McMaster-Carr, it does not exist...
